Old 04-11-2014, 09:55 AM   #11
TURBS's Avatar
Summer position first pic.
By pass closed
Winter position second pic
By pass open
TURBS
Sabre owners united!
ID:	49617   Click image for larger version
Old 04-11-2014, 01:21 PM   #12
hockeytownmom's Avatar
Well crap. Good know now, I guess. Thanks for the help and info.
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 04-29-2014, 06:03 AM   #13
Help, confused
By pass closed
By pass open
TURBS
I have my valves in the correct position but am getting no water from hot water tap at all. If I turn by pass to winter position I get 3 seconds very hot then ice cold. I'm so confused as to why this is happening. I can't find anything in forum to figure this out.
Any help is appreciated!
Dawn
Jkodko is offline   Reply With Quote
Old 04-29-2014, 06:06 AM   #14
Also, I have checked relief valve, water comes out. Running it on propane and city water.m
Old 04-29-2014, 08:57 PM   #15
Jkodko:
I'm guessing your hot water (HW) valve is bad. First time out last season, I thought I'd opened the HW valve. The handle turned, but the valve inside did not. Had forgotten to close the bypass, so I was getting 3 secs of hot (you get some conduction of heat through the closed HW valve) before the cold water from the bypass line took over. Mine also started leaking when I pulled the handle off and tried to turn the valve stem with my pliers.
I've got the metal valves, not the plastic ones as in the pics above.
2011 Traverse LT, 3.6L, FWD
Old 04-30-2014, 03:23 AM   #16
Originally Posted by rockfordroo View Post
Jkodko:
Thanks, that makes sense. I also have metal valves. The cold water knob actually came off and I had to turn with pliers. I guess I need to fix both.
I appreciate your help
Dawn
Old 04-30-2014, 12:06 PM   #17
bikendan's Avatar
Dawn, it's always helpful if you post what year, make and model you have or put that info in your signature line.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-30-2014, 12:13 PM   #18
Sorry, It's a 2012 30 Ft v-lite fkss
Old 05-02-2014, 08:09 PM   #19
Dawn
This is what happened... for the second time. I decided to fix it myself... make sure you have a pocket pex crimper.
Kristina & Family
Old 05-02-2014, 08:22 PM   #20
Smile Fixed!
Well it was actually the cold water valve. The valve must have been letting in enough water to fool me into thinking it was working. I cut the old valves and replaced both hot and cold with shark bite brass fittings. Super easy fix.
heater, hot water, water, water heater
