Old 04-10-2014, 10:36 PM   #1
hockeytownmom's Avatar
Hot Water Heater Issues...again
The bypass valve is broken - same issue as the last time in 2012, it just turns, but doesn't do anything else. And the hot water heater isn't filling with water unless I have both hot and cold faucets handles open. It gets hot just fine once it does fill, but then the water doesn't go to the faucets. Any ideas? I hate taking a shower in public showers, this stinks! -- The chick currently camping in TX and hating my showering experiences!
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 04-11-2014, 06:22 AM   #2
TURBS's Avatar
I'd replace the plastic valve with a brass unit.
Problem solved.
TURBS
Sabre owners united!
Old 04-11-2014, 08:32 AM   #3
Sure, but I don't think the broken valve is why I can't get water. The bypass is in the closed position, cold water is open, hot water is open. It just won't fill unless the cold water tap is on. And I can't "pull" the water from the hot water tank to the tap.
Kristina & Family
Old 04-11-2014, 08:44 AM   #4
Regardless, do what Turbs suggested. Problem solved.
Old 04-11-2014, 08:46 AM   #5
TURBS's Avatar
If the bypass is broke in the open position then the water will take the path of least resistance and flow thru the bypass and not water heater. Correct?
TURBS
Old 04-11-2014, 09:01 AM   #6
It's closed, it's been closed since I winterized it, per our instructions from our dealer. When I couldn't get the water into the tank, I tried to open the bypass and the valve didn't open, just turn.
I have to take it to an RV shop to get the valves redone, I can't get into the space well, and there's not a whole lot of line to work with.
Kristina & Family
Old 04-11-2014, 09:24 AM   #7
Hocky,is your bypass a (3 valve type or check valve type? Youroo!!
Old 04-11-2014, 09:31 AM   #8
Kaadk's Avatar
Typically the bypass needs to be opened to winterize and closed to use the tank. If it was closed to winterize, sounds like you got something backwards. Most likely it's actually open (or leaking aka open), causing the issue.
Having it repaired at least is the first step. See what happens from there.
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 04-11-2014, 09:50 AM   #9
TURBS's Avatar
Correct!
TURBS
Old 04-11-2014, 09:54 AM   #10
TURBS's Avatar
If you winterized correctly that valve should have been open .
TURBS
heater, hot water, water, water heater
