Old 07-03-2015, 12:07 PM   #11
The long and winding road...
Pretty much what others have said. Love the hybrid, but recognize the compromises. Annual inspection for leakage of any kind is mandatory, as with any RV. We store ours at the house as well, but use a cover and bunk end gasket protection over the winter.
The (all in fun) story so far...
Wife's family had a Jayco Jay Cardinal pop-up from the '70's. No leakage problems in over thirty years of use. Even replaced all the seriously worn canvas and cushions around year twenty as a family project! Jayco supplied all the replacement material pre-cut and ready to go! Local dealer was useless for this project, but direct contact with Jayco was superb.
The Cardinal was retired to Montana for stationary use by a young family building a log home; huge upgrade from the army tent! When the young husband mentioned the baby on the way and asked if the tires would make it the 600 odd kms to the dream house my Father in Law knew he had a buyer!
We replaced the tent trailer with a 2008 Jayco 23B hybrid. No bunk end leaks in eight years of use. Unfortunately the roof membrane was compromised while parking it for the winter, resulting in complete roof failure. The issue would have happened with a travel trailer with a similar roof membrane, and the offending tree is no longer around. Jayco has since revised their roof design to have a curved profile (like the Roo ), so the chance of total roof failure is greatly reduced. This is where we learnt the hard way about inspecting things.
With the last year replacement Roo we experienced bunk end leakage much like you describe. It was not discovered on the PDI as it was raining very hard, we were very excited with our new unit, and we did not open the bunks. It was the rear bunk, which is hard to examine in the up position. Big mistake! There was moisture all the way over to the side bunk.
We determined the leak cause; a giant lump of Dicor roof sealant dropped on the top gasket during manufacture. No leaks since we removed the Dicor and properly seasoned the bunk ends. I put a picture up of the Dicor here...
Cut to the chase...
The dealer was completely useless on this issue. Surprising as they sell a ton of hybrids. They insisted all three bunk ends needed replacement. Nothing happened for several weeks, as Forest River seems to have (quite rightly) completely rejected this notion. The dealership actually burnt down while our trailer was in for evaluation; fortunately not further damaged. The final dealer comedy was after waiting for about eight weeks for additional water testing (required by Forest River to consider a warranty claim) we were informed the night before our appointment that the dealer didn't have a garden hose at their temporary service location, so we were basically 'on our own' if we wanted to get in touch with Forest River.
Anyway, the learning was that if water gets by the gasket system it can get in to the unit interior through new unseasoned bunk ends. You did the right thing to reject the compromised unit, as who needs the hassle and heaven knows where moisture has got during shipment and storage. The other learning is that RV dealers are a unique bunch; needless to say we have made alternate arrangements for any additional service work and parts.
The Roo bunk gasket design is (in my view) not as good as the Jayco design. Kind of confusing as both manufacturers have changed designs over the years, but I give the nod to Jayco.
The Roo gaskets stand proud of the trailer wall, and use a very soft seal. Jayco gaskets are located within the wall, have a rain lip above the door crack, and have radiused corners rather than potentially leak prone square gasket corners with a gap. They also close much tighter, presumably on harder gasket material.
We didn't notice this design detail difference when we opted for a Roo rather than a new Jayco. Now that we are aware of the issue we are OK with it as a minor limitation, but mitigate things with PVC pipe over the gaskets (as shown in the linked thread) and a ADCO cover during winter storage. Our concern is in Calgary we get very frequent freeze and thaw cycles over the winter, and we worry about ice doing the same thing as the Dicor sealant.
That said, the Roo has nicer features and finish, and we are overall happy with the unit, see it as a huge improvement over the Jayco.
Sorry for the length and ramble. The hybrid positives far outweigh the concerns.
Calgary AB
2014 Roo 233S
2011 Ford Econoline Club Wagon
stugilmour is offline   Reply With Quote
Old 07-03-2015, 12:17 PM   #12
DK-in-SC's Avatar
We've had our 23IKSS for a year now. We had some initial leaks but after properly seasoning the tent ends, the front bunk is totally dry. Most of the back bunk stays dry but I do have one corner where we sometimes get a drip. Some seam sealer should do the trick and is on my list for this weekend.
The other type of leak that people experience is leaks while the camper is closed up. We had some minor leaks in the bunk ends during the first few months of ownership, but each time I was able to figure out why. Once it was because some of the fabric was trapped in the seal. Another time there was some pine needles and debris on the top seal when we closed it up. I've realized that the edges of the bunk doors that contact the seals need to be perfectly clean. I also go up on a ladder and check the top seal before closing up. By doing these two simple things we've had zero water while stored or during travel.
You made the right call on the first trailer. Hopefully the next one looks better.
I live with fear every day, and sometimes she lets me go fishing.
2015 Shamrock 23IKSS
2008 Ford Expedition EL
DK-in-SC is offline   Reply With Quote
Old 07-03-2015, 02:05 PM   #13
Thanks all for your input. Very good information, I appreciate it.
TV: 2013 GMC Sierra Crew Cab 5.3L
2016 Shamrock 23IKSS Hybrid TT (2015 - ??)
2008 Fleetwood Niagara Pop-Up (2010-2015)
CampTx is offline   Reply With Quote
Old 07-03-2015, 02:50 PM   #14
Maris's Avatar
We had our 2010 Shamrock 23ss for 5 years and loved it. Never had a leak even in torrential rain. We did have some issues with delamination but Forest River was very helpful in solving the problem. The perfect trailer for a family and light and doesn't take up too much room in the driveway. Like all trailers though, inspection and regular maintenance is important.
Maris is offline   Reply With Quote
Old 07-03-2015, 05:33 PM   #15
Water leaks
Yes, campers do leak. First night out with Cedar Creek, heavy rain storm, water running out of ceiling. Had to get out pots and pans. Back to dealer and they found the air conditioner was not mounted over the roof opening correctly. a 1/2 inch out of line let rain run right in. Good warranty by Forrest River, they added another year bumper to bumper
hamshack is offline   Reply With Quote
Old 07-03-2015, 07:32 PM   #16
Had our Roo 19 for 3 yrs. Never had a leak. From reading this forum for the past 3 years, it seems like it's either feast or famine with leaks.
1988 Coleman Sequoia - popup (1987-2007)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
Old 07-03-2015, 08:40 PM   #17
RV (Not so) Noob
Glindz233s's Avatar
We've had our 2015 shamrock 233s since just last July but have had no problems with leaking. We just got back from a 2 night camping trip where it rained heavily but still no leaks. I guess we're one of the lucky far. I just keep an eye on it.
Glindz233s is offline   Reply With Quote
Old 07-03-2015, 10:08 PM   #18
RedStick's Avatar
I've got a 2013 23ss - the only leak detected was when the tent ends weren't quite seasoned good enough.
Even then, I noticed just a couple of drops coming in through the front bunk - knock on wood!
2013 Rockwood Roo 23ss
2012 F150 Ecoboost
Camped for 12 nights in 2015 - too many cancellations
Camped for 25 nights in 2014!
Camped for 24 nights in 2013!
RedStick is offline   Reply With Quote
Old 07-04-2015, 07:00 PM   #19
My 1999 wildwood and 2006HR savoy both leaked terribly. My 2010 flagstaff had a very small front window leak that was corrected with a window adjustment.
rlocicero is offline   Reply With Quote
Old 07-04-2015, 07:51 PM   #20
we picked up our 2015 23ikss roo in april, did 2 nights camping this past weekend .the first night we had condensation on the inside bunks. pugs will be put on for the next trip second night it poured rain. no leaks. love the layout. met every expectation.
muskoka01 is offline   Reply With Quote
