Old 01-16-2013, 01:40 AM   #1
How did you add a second battery to the Roo?
I am planning on changing over my ROO from a single Marine battery to Dual 6v batteries. I was wondering if any of you went to dual batteries (12 or 6) where did you put them?
My Roo has a combo Propane / Single Battery cover, and I was interested in seeing how others got around this problem before I reinvent the wheel.
Here is a photo of a Roo with the cover I'm referencing:
Pezman is offline   Reply With Quote
Old 01-16-2013, 04:27 AM   #2
Remove (1) propane tank? If cold camping disregard,if not 20# of propane lasts a long time. Youroo!!
Old 01-16-2013, 05:14 AM   #3
Triguy's Avatar
That would be the easiest way to use two 6-volts with your setup.
My Shamrock is a bit different than what you have so, for me, it was just a matter of finding two 6-volts that would fit in the battery tray. My batteries are between the dual propane tanks and the trailer.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 01-16-2013, 11:36 PM   #4
bikendan's Avatar
i don't think that's a stock cover, though it might have been an option at one time. that Roo is a 2006 or older.
most Roo's have just the tanks covered, not the battery.
on my Roo's A-frame, the battery was mounted across. i mounted the two new ones, length-wise and they fit with the boxes bolted and a strap around both boxes.
to get two batteries, you'll have to ditch that cover of yours.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-17-2013, 02:30 AM   #5
It is a (Standard) cover for Roos.Our (2004) Roo (New) came with that cover & the terrible threaded swing clamps for the bunk ends. Youroo!!
Old 02-09-2013, 08:36 PM   #6
cmcct's Avatar
I chose to run 2-12 volt batteries. I built a rack to support them that fits in the space where the single battery was. Wouldn't work with your cover, but I would never go without 2 batteries.
ID:	24154   Click image for larger version
Tow Vehicle: '92 F350, Crew Cab, 4X4, Cummins 5.9 24 Valve, 6spd.Driver:Clint, Navigator:Melanie, 1 dog (Great Pyrenees/Akbash cross) and now a cat too. Mission Statement: Just another adventure! Towed vehicle:2009 Roo 19 with lots of mods!
cmcct is offline   Reply With Quote
battery
