Old 12-25-2014, 07:26 PM   #11
Is there a good reason to remove the water filter?
Would you place the 2" memory foam over or under the heated mattress?
What is and where do you mount the 5" fence post w/ gutter tray Poop-Tube carrying device?
1. Many folks have had trouble with the clear filter cover coming loose and putting water all over their camper. (I haven't had problems with mine.)
2. We put our 2" memory foam on top. Didn't seem to hurt the heat from the mattress.
3. The fence post is from Home Depot (sometimes hard to find) and the gutter inside is from Lowes. Mount it under your frame. Lots of folks do it many different ways. If you're comfortable drilling holes in your frame, you can strap it up. I used stainless steel nuts/bolts/fender washers and "clamped" it to the flange of the frame. See attached pics and diagram of the mounting.
Name:	Sewer Hose #1.JPG
ID:	67855   Click image for larger version
Name:	Sewer Hose #2.JPG
ID:	67856   Click image for larger version
Name:	Sewer Hose #3.JPG
ID:	67857   Click image for larger version
Name:	Sewer Hose #4.JPG
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 12-26-2014, 06:49 AM   #12
J R
Screw with a Roo
Thanks Ed and Rockfordroo!
Jim & Char
2011 Coachmen Encounter 36KS
Towing a 2005 Jeep Grand Cherokee
J R is offline   Reply With Quote
Old 12-28-2014, 05:41 AM   #13
If the water filter is removed from the interior, how does one filter the water from the on-board FW tank.
Pappadeaux is offline   Reply With Quote
Old 12-28-2014, 11:05 AM   #14
Is this something I need? We just slide the sewer hose inside of the fender. Pop off the black cap and slide it in, replace the square black cap, done.
syogerst is offline   Reply With Quote
Old 12-28-2014, 11:27 AM   #15
Jimandchris's Avatar
Some have trouble making it fit in the bumper, the elbows won't fit, and it can cause rusting inside the bumper tube. I've been thinking about adding the stinky slinky holder, might do it this coming spring.
Jim
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
Old 12-28-2014, 07:48 PM   #16
bikendan's Avatar
I think you meant bumper, not fender.
most use the bumper for hose storage. The stock black end caps will often fall out, so watch them. There are better options than those stock caps.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
roo
