Old 10-24-2015, 07:18 AM   #1
Summer2Go
Summer2Go's Avatar
How do your heated mattresses work?
I finally decided to see how well my heated mattresses would keep us warm on a cold night and plugged them in to see. Well I can't feel any heat in or on the surface of the mattress. There is warmth around the plug area, but that's it. I laid on one thinking the elements were deeper inside the mattress, and can't detect any heat. The controls are on high-6. I also left them on for an hour and came back to check. ....?
Summer2Go is offline   Reply With Quote
Old 10-24-2015, 07:22 AM   #2
urocav2001's Avatar
The ones in my 13 233s only worked a little bit and took hours to warm up, these one in the 16 233s put off tons of heat especially if you turn them on and put a blanket or sleeping bag over the mattress, nice and cozy when you go to bed
urocav2001 is offline   Reply With Quote
Old 10-24-2015, 08:30 AM   #3
DK-in-SC's Avatar
Ours work well. It isn't hot like an electric blanket, but when you climb in bed the mattress isn't cold either. They do take some time to warm up. I will usually turn them on an hour or two before bed. Also keeping a blanket on top of the sheets will help to trap the heat. We have a three or four inch mattress topper on our mattresses and the heat comes right through them.
I live with fear every day, and sometimes she lets me go fishing.
2015 Shamrock 23IKSS
2008 Ford Expedition EL
DH-DW-D3K-DMTTSAP
DK-in-SC is offline   Reply With Quote
Old 10-24-2015, 10:21 AM   #4
Same here. Work well for us. Turn on 2 hrs before bed and it is pretty comfortable when you crawl in
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 10-24-2015, 11:08 AM   #5
bikendan's Avatar
They work better when you are actually in the bed.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-24-2015, 11:15 AM   #6
Purdyquibb's Avatar
I thought ours worked really well. I've never had to turn them up to 6. We also use an egg shell mattress pad and still feel the heat. However, When I plug mine in they never go off again the entire trip, Even during the day.
Purdyquibb is offline   Reply With Quote
Old 10-24-2015, 11:56 AM   #7
I installed a heated mattress pad cover. Has 6 heat zones and 4 heat temps. Works great for my fybromyalga.
j free is offline   Reply With Quote
Old 10-24-2015, 12:11 PM   #8
Same here. In fact, when I turn them on (an hour or so before we go to bed) I set them to 6. But once we go to bed I turn them back down to about 2 because my wife finds it to be too warm with them on. We, too, have a mattress topper.
drhroo is offline   Reply With Quote
Old 10-24-2015, 12:28 PM   #9
camp_g_dess
ours did not work as well as what we needed and it was terribly uncomfortable so we just bought a new regular mattress and use a down comforter and with the furnace we've never been cold at all.
rkmavis is offline   Reply With Quote
Old 10-24-2015, 12:47 PM   #10
we have a 2012 flagstaff 21fbrs with a heated mattress, which works well -- as others have commented, be sure to keep it covered, turn it on an hour or so before using it -- we've found that a setting of 2 - 3 is most sufficient -- the original mattress was replaced under warranty because one side was not working -- if you think yours is not heating, use an ohm meter to check between the pins on the mattress plug -- our mattress has a 3-pin plug; for that type, measure the resistance between center pin and each of the other pins, one at a time -- any reading from zero to a couple hundred ohms means that part of the grid is okay; if infinity is measured, that loop is open and not functioning -- hope this helps --
Wanderers thru Wonders
Flagstaff 21FBRS led by F150 5.4
Sun & Moon, direct us...
don1 is offline   Reply With Quote
