The seals are kind of a pain to remove if the adhesive is still good on them. Ive tried rubbing alcohol, wd-40, adhesive remover, and scotch brights. What worked best for me is to heat them with a hair dryer, or a heat gun if you can get the temp low enough and slowly pry off with a plastic putty knife. Go a couple inches at a time. I got most of the adhesive and seal off this way but I still had some scrubbing to do to get the rest off. Once you get a good clean surface, the new ones go on easy. Just peel and stick. Just make sure they're straight.
021 Ram Rebel 1500
2017 Shamrock 233s
Waterloo, Iowa
