03-24-2016, 10:56 AM
Humidity and heat
We just got the 233s. Curious how the AC performs with high humidity and heat? We upgraded to 15k AC. Anyone with experience running the AC in humidity and heat and how cool can it keep the trailer?
03-24-2016, 11:29 AM
Solar blankets or PUG's over the tent ends will help. Plus I would suggest doing the Reflectix mod in the bunk windows. We did both when we had our hybrid and even with our standard 13.5K AC unit the inside was quite comfortable. Both do a great job of retaining heat when running he furnace too.
03-24-2016, 03:21 PM
I find the 13.5 to be perfect for my DK and I can always close one end if I need to be a little more aggressive. As Wisc said the reflectix makes a noticeable difference. I ordered Ecofoil because it is a midwest company providing it and they give me scraps but same difference. I bet your 15k will be excellent at your larger size. In my experience it is almost better if it has to run longer and with our hybrids it often does.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
03-25-2016, 10:10 PM
Add my vote to pugs and the reflectix mod, we go to myrtle beach twice a year in our 233s and they make a big difference, especially for the rear bunk.
03-29-2016, 11:36 AM
13.5K works perfectly on my 23IKSS with both ends open and both slides out in direct sunlight because I hate shade. I usually have to turn AC up bc it gets like the Antarctic in the Roo
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
03-29-2016, 11:41 AM
Our ac cools our trailer and keeps it cold- even in the Mid-July air so thick you can almost swim heat and humidity. There were several times that we turned it off because we were too cold! We do use dehumidifiers inside.
ETA: Whoops didn't see that this was posted in the hybrid section. We don't have a hybrid.
Kelly and Stephen with Daisy, Lily, and Roxy!
Run Free Sweet Riley 2009-2015
Visit our blog for more information and details!
www.kels4g.com
03-29-2016, 07:08 PM
Sorry to say I have failed to join the PUG's & reflectix crowd...I TOTALY understand the reasoning for both, but have simply not had the patience nor desire to add more to our normal 233 stock configuration. As a pretty much strictly Florida (HOTTT & HUMIDDDD) camper I can report that stock canvas ends in direct sunlight (non-shaded campsite) will warm up without those add-on's....but our stock 13.5 AC does just fine as we aren't typically sleeping during the day anyway. In a shaded campsite, even during mid day the tent ends can be cold if you run the AC cool enough, for me not a problem especially since the electricity bill is not metered while I camp!
Ed & Chris, Empty Nesters (missing Josh & Jaclyn)
along with Blue & Tessa, Cat Explorers!
2020 Rockwood Roo 235s
2019 F-250 Diesel 4x4 Super Duty
03-29-2016, 08:31 PM
I am all stock too no Pugs or Reflectix, I don't have issues but if one of my ends is in direct sunlight I sometimes close them just so the AC doesn't have to work hard in the day, but always sleep in them at night
03-30-2016, 06:41 AM
I have pugs and a 13.5K A/C unit and it works fine. At times I have to adjust the temperature up as it's too cold. No problem with keeping the trailer cold.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
03-30-2016, 07:21 AM
The foil wrap is so cheap you should try it once...amazing what a difference it can make. That said I have run naked canvas many times as well and I totally agree...the ac had no trouble keeping cool.
2013 F150 FX4 EB
04-01-2016, 09:48 AM
Broken Toe
I have the 15K on my 21SSL. We usually run only one bunk open, but occasionally run with both. The A/C keeps the body of the camper very cool on even the hottest days, but the bunk ends can get warm in the direct sunlight. The canvas will get hot to the touch from the sun, and that warms the bunk end area up.
PUGS almost totally eliminates that condition. I keep a cheap $16 box fan going all day as well just to keep the air moving around. While I like shady spots as much as the next guy, I no longer fear direct sunlight like I did with my old Class "A". That thing was an oven in direct sun.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
04-01-2016, 12:02 PM
We have a 2015 Shamrock 19fd with 13.5 AC. Even in Carolina sun, the AC is awesome. It keeps everything cool. However, you have to run it on high during high outside humidity and adjust the temperature control or the unit will freeze up. Just FYI
