Old 03-21-2014, 09:00 PM   #1
Cheffonade's Avatar
HVAC question
Hi all,
So we are on our first camping trip with our 2004 Shamrock. So far, so good except for what appears to be a broken propane regulator. Our popup had AC and a furnace. There was a heat strip in the AC but it warmed minimally. My question is this...does anyone know if the AC has a heat strip or is the heat strictly powered by propane? I didn't even try it last night, just assuming it wouldn't help. Thank goodness for sleeping bags! It wasn't too bad at 45 degrees but would have been a lot more comfortable with a little heat. Thanks!
Cheffonade is offline   Reply With Quote
Old 03-22-2014, 05:45 AM   #2
Todouble's Avatar
I've never seen a heatstrip in an ac on a pop up. Doesn't mean you don't have it but most likely not. Your pop up Heater is propane only. Also a lot better than that little heat strip would do anyway
Todouble is offline   Reply With Quote
Old 03-22-2014, 06:02 AM   #3
AquaMan's Avatar
Originally Posted by Cheffonade View Post
Hi all,
Try turning the gas off at the tank, and then turn it back on VERY slowly. Sometimes the valve can be opened too quickly and enact the safety feature of the regulator.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 03-22-2014, 07:13 AM   #4
Cheffonade's Avatar
Thanks! I'll try that
Old 03-22-2014, 12:01 PM   #5
bikendan's Avatar
since you don't specify what model shamrock you have it's hard to say.
those with ducted a/c do not have a heat strip capability.
Those without ducted a/c may have that capability.
it all depends on which brand and model a/c you have.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-22-2014, 12:04 PM   #6
Cheffonade's Avatar
Gotcha. It's a 232 and the AC is ducted.
Old 03-22-2014, 06:00 PM   #7
And if you've got shore power available, get a small 1500 watt heater. It will keep the chill off.
2011 Traverse LT, 3.6L, FWD
Old 03-22-2014, 06:20 PM   #8
Cheffonade's Avatar
Thank you I think I will do that!
Old 03-23-2014, 03:05 PM   #9
Post
If the a/c unit has a "heat" setting on the control panel, then it is heat strip capable. It does not mean it has a heat strip. The heat strip is usually an optional item. As far as installation, they are plug & play. You can remove the interior cover of the a/c to check if you have one.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 03-27-2014, 02:37 PM   #10
Can also look into the RV comfort systems unit for electric heat, we had one in our popup and it ruled, I will be putting one in my next TT for sure.
10 CTS AWD Wagon
10 BMW X5 35D
08 Mercedes GL320
08 Outback 21RS
Talonman is offline   Reply With Quote
