Old 09-15-2012, 08:54 PM   #11
Schaal's Avatar
This is depressing!
Schaal is offline   Reply With Quote
Old 09-15-2012, 09:21 PM   #12
hockeytownmom's Avatar
Originally Posted by Schaal View Post
This is depressing!
Yep.
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 09-15-2012, 10:29 PM   #13
kwillmott
Guest
Posts: n/a
Believe me it is frustrating and depressing. I spent $22,000 on a 2009 Roo had 2 bunks leak and a flood that turned all the wood wet and then rotten and I can't use it or sell it. Will never invest in another RV/trailer again. The bunk ends on these will leak and cause water damage or worse mold.
Old 09-16-2012, 02:08 PM   #14
Canadian Member
itat's Avatar
Schaal and Hockeytownmom, do you know how the water or moisture is getting in there?
On mine, I believe there are a couple possibilities. The screws along the top of the frame around the bed door opening are not all flush. One in particular was put in on such an angle (maybe 70 degrees rather than 90 degrees) that it keeps the door edge seal from fully contacting the frame and provides a path for water to enter. After a hard rain I can see signs that the water is getting through at that one screw. I'll be resetting them all and putting some Proseal caulking in the holes and on the screw heads. IMO, it's a poor design to have the screws located under the edge seal and bad quality control at the factory that doesn't ensure the screws are set properly. The new bed end design doesn't have this problem but those owners are still reporting water problems.
The other possibility is that the bottom of the frame around the opening seems to be angled inward when the trailer is sitting level so water that makes it in there is trapped and can't completely drain. I may try putting a bead of Proseal there to keep it away from the bottom of the bed door.
Of course it's also possible the the vacuum bonding process at the factory is suspect and the doors are delaminating simply due to a deficiency in that manufacturing process.
Are there any owners with this problem that live in the south or in desert areas where you don't have humidity and freeze/thaw cycles like we do in the northern States and Canada?
I'd appreciate any other suggestions, but it seems to me that this problem has been around long enough and frequently enough that the manufacturers, not just Forest River because they all have this problem, should have figured it out by now. I have a step-sister who had this issue on their Laredo 5th wheel, too.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 09-17-2012, 12:41 PM   #15
I'm not really sure how it's getting in. My delamination is only on the door and not on the wood that a portion of the bed lays on.
Kristina & Family
Old 09-17-2012, 12:42 PM   #16
Schaal's Avatar
The company should be @ fault no if our camper's are less then 5 years old! It is unacceptable we are paying top $$.
Old 09-17-2012, 12:44 PM   #17
Schaal's Avatar
So far mine is only on the outside, all along the bottom by the hinge, and only on the front of the camper.
Old 09-17-2012, 01:25 PM   #18
Canadian Member
itat's Avatar
I agree that the manufacturers have to make good on these delamination problems for more than the 1 or 2 yr factory warranty period. FR seems to be taking some responsibility for my problem.
If domestic car manufacturers have seen the light on quality control, why hasn't the lightweight RV industry? In the auto industry, it took asian manufactuers to enter the market to force them to improve. Let's hope that doesn't have to happen to the RV industry.
I have to disagree with your statement about "top dollar". Compared to the price of a new car these days, buying a 21-23ft hybrid for under $20,000 would be a bargain if the quality is comparable. For comparison purposes, have you seen the price of an Airstream lately? Much higher quality, but much heavier and no slide outs. And at least twice the price of an "ultralight" like a Roo.
Old 09-17-2012, 01:54 PM   #19
Schaal's Avatar
Of all the Hybrid Campers that I shopped for the Roo seems to be the most expensive
Old 09-17-2012, 02:18 PM   #20
Canadian Member
itat's Avatar
If you are looking strictly at the "ultralights" with the laminated sidewalls and aluminum stud frames like those produced by Forest River, Keystone, Dutchmen, Heartland, etc., the Roo might be top dollar. When I was looking at the actual trailers in showrooms, the Roo seemed to be above average in build quality based on what was visible on the new units.
My "top dollar" comment is based on trailer size and features, and on that basis, the ultralights like the Roo can be considered good value so long as there aren't significant quality issues. Airstream doesn't make hybrids so perhaps that was a poor example on my part.
bed
