Old 08-15-2016, 01:49 PM   #1
Hydroflush advice
This thread is specific for Roo owners please. I need advice for the black tank. Already searched forum and couldn't find specifics. Would the hydroflush help with FULLY cleaning out black tank? There is a lip in our tank that doesn't allow full draining and I am tired of carrying five gallon buckets into camper to try to flush all the poop out! After several trips, there will still be special surprises floating around. Our camper is "permanently" parked now in a spot so I cannot drain like I used to at campgrounds. Also, the hydroflush has a 90 or 45 degree angle option. Which one for the Roo? BTW, I do not want to try the wand method.
tuckerfamily is offline   Reply With Quote
Old 08-15-2016, 02:09 PM   #2
dodosmike's Avatar
What about a garden hose fitting attached to 3' of copper pipe and a 90* fitting on the end? Push it down the hole and turn it and raise/lower it as needed. The water pressure should (?) be enough to dislodge the "poop on your lip".
I made the hose/pipe things to rinse out my HWT sludge. Same theory, vastly different application...lol
dodosmike is offline   Reply With Quote
Old 08-15-2016, 02:38 PM   #3
Old Eeyore's Avatar
You have to look at how your black tank hooks up to the hose connection. It must be a straight shot up into the black tank. Neither of my Roos met that criteria. The 23IKSS has so many bends that there's no way anything is going to go up into the tank - ever.
Plan B might be to put a hose adapter on your bathroom sink faucet and a short piece of hose from there to the toilet. You can choose - or not choose - to use a wand of some flavor from there.
2016 Roo 23IKSS / 2011 Tahoe
2011 Roo 21SS / 2011 Tahoe
2006 Bayside / 2006 4Runner
1999 SantaFe / 2001 Sienna
1967 Nimrod / 1998 Outback
Old Eeyore is offline   Reply With Quote
Old 08-15-2016, 11:12 PM   #4
Why not install a Tornado Rotary Tank cleaner at the opposite end of the tank?
I think you'll find it works better than those hydro-flush things. Watch this video:
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 08-16-2016, 08:21 AM   #5
Head Rambler
I know that you said you wanted only Roo owners, so please disregard this if you choose.
Roo's aren't much different than a lot of other RV's in regard to black tank draining and flushing. In our previous TT I used a version of the Hydroflush and I still use it on our current RV.
In my opinion it will certainly help in cleaning your black tank if you use it correctly.
First you'll need a valve on the outlet side of it, so you can close off the flow. Because in all likelihood it's not going to shoot a stream of water straight into the tank. There's too many crooks and bends in the plumbing for that to happen.
1) Drain the tank as best you can.
2) Close the outlet valve on the Hydroflush and turn on the water into it.
Let the water run until the black tank is about half full.
WARNING: DO NOT leave the flush unattended, AND keep a close eye on the level in the tank!
3) Once the tank is about half full, open the outlet valve fully and let the tank drain again.
4) Repeat these steps a couple of times and your black tank will be as clean as you can get it.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-16-2016, 11:03 AM   #6
This thread is specific for Roo owners please.... ....BTW, I do not want to try the wand method.
I have tried the wand method and certainly not happy with the need to drag a garden hose into the RV. That said, just locally ordered one of these to get around this issue; first saw the hose attachment here on a recent thread. Figure I will be able to easily and adequately flush the system from the sink faucet at the dump station or last campground we use.
https://www.amazon.com/Valterra-A01-.../dp/B0006MTRCO
Realize you mentioned not wanting to try the wand, but I figure with this enhancement it should be OK. Won't arrive until next week.
Regarding the conclusions of the video, our 233S has two 90 degree elbows in the black tank drain, so looks like only the only reviewed product that will work is the permanently mounted devise. I didn't like the potential installation hassles. Also the dump station we most often use does not seem to have a working fresh water hose, so none of the featured methods would be very handy anyway.
HTH
Stu
Stu
Calgary AB
2014 Roo 233S
2011 Ford Econoline Club Wagon
stugilmour is offline   Reply With Quote
Old 08-16-2016, 11:27 AM   #7
Dave Lyon's Avatar
My 23SS has two bends in the black tank discharge line as well. As you've stated a back flush is not effective.
When I empty the black tank, I stand over the toilet and dump a 5 gallon jug of water into the tank just as it is almost empty. This help flush out almost everything.
When I get home I fill the tank up with water and drain it again as well as use a wand down the throat of the toilet........seems to work.
Dave, Southern,ON
2009 GMC K1500 4x4 Crew Cab
2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 08-16-2016, 11:34 AM   #8
What do you guys do with the wand when you're done? My DW would be very concerned about where I put it.
Old 08-16-2016, 12:00 PM   #9
Dave Lyon's Avatar
I hang it on a nail on the garage wall. The wand shouldn't get dirty.
Dave, Southern,ON
2012 Roo 23SS
Old 08-16-2016, 12:21 PM   #10
Thanks.
But my DW will tell you: anything you put down your toilet is going to "get dirty."
And I don't have a garage.
