Old 09-14-2015, 08:17 AM   #11
pxt
Looks like I'm going to have to fabricate a gutter system above the upper seal area.
pxt is offline   Reply With Quote
Old 09-14-2015, 08:17 AM   #12
RooVader's Avatar
No, not really any adjustment. I think the compression is purposely very light as you are just relying on the rubber gasket lightly sealing all the way around. Maybe there was a bad run of seals and they just need to replace the seal on all 3 of them? I don't think the actual closing system itself is problematic as even though mine doesn't close tightly it is still a dry seal all the way around.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
RooVader is offline   Reply With Quote
Old 09-14-2015, 08:20 AM   #13
RooVader's Avatar
That pvc/hose mod is a great idea either way...I have that on my list as preventative medicine.
2013 F150 FX4 EB
Old 09-14-2015, 08:27 AM   #14
pxt
Dropped 16k on something that's leaks stinks.....I prefer the gutter system due to not having to remove the pvc to open the doors?
Old 09-14-2015, 08:36 AM   #15
RooVader's Avatar
Is it brand new? I mean is it possible there WAS something caught in the openings at some point and it caused the gaskets to deform a little bit? Maybe they will smooth out or new gaskets would fix it?
2013 F150 FX4 EB
Old 09-14-2015, 08:45 AM   #16
pxt
Yes, brand new/ even with new seals after a major rain I'm going to wonder if it leaked. I guess I'm suffering from trama....lol.
Old 09-17-2015, 07:51 PM   #17
Summer2Go
Summer2Go's Avatar
If it makes you feel any better, every new camper has some issue. They are complicated little houses. My 2016 183 leaked the first time it rained, and then never again. But my toilet needs fixing.
Summer2Go is offline   Reply With Quote
Old 09-17-2015, 09:15 PM   #18
pxt
Did you do anything special to stop the seal leak?
Old 09-18-2015, 04:30 AM   #19
My dealer recommended installing a gutter system above the bunks. It's basically the same channel used along the sides with its own little downspouts. Seems to work great. Not any water inside (yet). Actually there was none before so this was a preventive measure. I had the dealer do it because I didn't want to drill holes in my new unit. My opinion....the factory should install them during the build. Why have gutters over the mostly solid sides and none over the ends where water intrusion is more likely?
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 09-18-2015, 05:17 AM   #20
pxt
Hi, can you please send me a picture of the gutter system? I would really appreciate it.
