Old 05-03-2014, 06:35 PM   #1
keven's Avatar
Installed Quickie Flushes
A while back went ahead and installed 2 Quickie flushes in both tanks. Installation was fairly simply took maybe 2 hours total from start to finish. The one thing that isn't in the pic is I installed a pressure regular on each Quickie Flush to make it easier to switch hoses. You can't believe how much nicer it is to clean out the tanks. Click image for larger version
Name:	ImageUploadedByForest River Forums1399159977.203503.jpg
ID:	51520Click image for larger version
Name:	ImageUploadedByForest River Forums1399159989.564206.jpg
ID:	51521Click image for larger version
Name:	ImageUploadedByForest River Forums1399159998.930076.jpg
keven is offline   Reply With Quote
Old 05-03-2014, 06:51 PM   #2
Plain Old Member
Nice job. On earlier units, we had put 2 flushes per tank tied into 1 inlet. I hard piped mine with pex. Also put the brass quick connects, inlet valve and back flow valve. The tubing it comes with is not the greatest, but it works. On some, I've drilled the jet holes out slightly larger for more flow.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
