So, I installed a hard wired surge protector and EMS unit to replace one I had been using at the podium. I researched on this fourm (which was very helpful) where to place it and came to the conclusion there are 2 placement options.
- Under the bathroom sink where the power first enters the camper.
- Behind the power converter.
I chose behind the power converter. The issue I wrestled with is where to place the display screen, I personally cringe at drilling into the cabinetry, so I wanted to share the placement of mine to give others that may be considering installing this setup another idea.
I routed the cable to the rear storage area (by the water filter) and installed in the removable partition.
Whether you choose option 1 or 2 above, you could do this easily, as there are open pathways from either place.
This achieves 2 things;
- (Most Importantly) You can plug into the podium at a campsite and check for errors before you set-up.
- You don't have to drill into any cabinetry.
TV: 2017 F-150 3.5L Ecoboost Max Tow & Payload Package
Camper(s):
2016 Shamrock 23IKSS Hybrid TT (2015 - ??)
2008 Fleetwood Niagara Pop-Up (2010-2015)
