Old 10-15-2011, 10:11 AM   #1
buzzmonster's Avatar
Interesting observation on weights
I was winterising the trailer and I spotted the stamping on the TT hitch that gives a maximum weight of 5000lb on our Roo 21RS,which is interesting as the max weight according to the specs and the yellow sticker in the trailer exceeds this at 5235 lb.
We are not that close to either figure - but I find it strange in this day and age that Forrest River appear to be exceeding the gross weight stamped on the TT hitch.
OR am I misunderstanding something here ?
ID:	8556   Click image for larger version
2011 F150 Ecoboost Screw 4x4 c/w max tow
2010 Roo 21RS
buzzmonster is offline   Reply With Quote
Old 10-15-2011, 11:31 AM   #2
Triguy's Avatar
That is interesting. I went outside and decided to check the stamping on my tongue.
You can see on mine that it states not to exceed 10,000lbs gross weight. The dry weight on the sticker says 4464, which isn't much higher than yours is.
Name:	2012 Shamrock 233S Trailer Tongue Stamping (640x480).jpg
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-15-2011, 03:26 PM   #3
The difference is the size of coupler 2" ball has lower max rate compared to a 2 5/16"
~Andrew
99 F250 Super Cab Short Bed 7.3 Powerstroke
84 24' Yellowstone Camino (oldie)
http://rvpdi.com
Acableguy06 is offline   Reply With Quote
Old 10-15-2011, 03:34 PM   #4
Triguy's Avatar
Yes, but what's interesting it why that is on his trailer, which is only 2 feet shorter and 900lbs lighter (GVWR) than mine. There just doesn't seem to be that much of a difference to justify the lighter hitch.
Scott
2012 Shamrock 233S
Old 10-15-2011, 08:23 PM   #5
rbq
Somewhere in the back of my mind I recall that Forest River made a mistake several years back & used the wrong hitch or frame on some of the trailers. I thought that they took them back & put the right one on as part of the warranty. Might want to check this out with them.
rbq is offline   Reply With Quote
