Old 09-27-2011, 09:07 AM   #1
Hybrid Owner
Interior Bulb
I own a 2011 Rockwood Roo 19. On our first trip the bulb over the stove on the range hood blew. I am unable to see the number on the bulb since it has worn off. I also have had no luck with the camper owners manual or the dealer that I purchased it from. If anyone could share any information on this I would appreciate it.
bbqlover is offline   Reply With Quote
Old 09-27-2011, 09:46 AM   #2
Triguy's Avatar
I replaced that light bulb with an LED but can't recall what connector it used. Possibly the same as any other light in my Shamrock but I'd have to double-check.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-27-2011, 09:48 AM   #3
frankm's Avatar
If your range hood is a Heng's then the bulb is 12v type 912 bulb. Just lost ours too this past weekend and called Heng's customer service. Click Hengs Industries for info.
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 09-27-2011, 12:20 PM   #4
miatared's Avatar
Same here - I changed it to an LED (36 SMD) it has the same connector as the other bulbs in the trailer.
Got the LEDs from eBay - shipped from China for under $3 each- I changed all of them. Little power consumption now.
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 09-27-2011, 12:47 PM   #5
You can get a 912 at any auto parts store, even Wal Mart. A 921 is the same physical size, only brighter. This is a common bulb in the third brake light on autos.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-04-2013, 04:15 PM   #6
ProjectPro's Avatar
I have a similar problem. The bulb in my Winntec range hood in my 2012 VCross VFK27 blew, and I couldn't read the number. The hood label stated maximum of 10 watts, but I couldn't find a 10 watt bulb. I found a 7.5 watt bulb, but the light is too dim to be useful. A 922 bulb puts out great light, but is 12.5 watts and burned a hole in the plastic diffuser. Like BBQ, I found the user's documentation and the dealer to be useless.
I ordered an LED replacement, but it doesn't fit - the assembly is too wide for the fixture. Any ideas for conventional or LED replacements? Can I use a xenon-filled bulb, or do they run hot like halogens?
ProjectPro is offline   Reply With Quote
Old 06-05-2013, 07:03 AM   #7
Dave Lyon's Avatar
Ditto - I replaced my hood light with a 921, it is brighter than a 912.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 06-05-2013, 08:29 AM   #8
ProjectPro's Avatar
912 / 921 Wattage
No surprise that it's brighter - the 912 is listed at 13 watts; the 921 18 watts if I'm looking at the documentation correctly. Both too much for my wimpy hood. Sorry to coattail onto this thread - I should start a new one in the VCross section.
