Old 10-16-2015, 03:49 PM   #1
Interior led lights
I was looking at the ceiling lights in my 21ss and was wondering how you remove the covers. There are two small indentations on each side of the light next to the ceiling, but I don't want to just stick a screw driver in there and pry.
Stephan
2016 Roo 21ss
1982 Ironhead is offline   Reply With Quote
Old 10-16-2015, 04:17 PM   #2
If there like mine. Slide them back away from the center of the fixture. Then pull down on them.
Kevin & Judy is offline   Reply With Quote
Old 10-16-2015, 04:19 PM   #3
Head Rambler
The lens slide away from the center partition where the switch is about 1/4" and then pull down to remove.
Don't stick a screwdriver in the indentions, but stick a small screwdriver in between the lens and the switch partition and gently slide the lens back a little until you can pull it down.
Gotta go campin!
Old 10-16-2015, 05:49 PM   #4
These are a one piece oval lens.
Stephan
2016 Roo 21ss
Old 10-17-2015, 07:00 AM   #5
ROCAMPER's Avatar
I had to stick a screwdriver in and pry. Felt like it was going to break, but didn't.
ROCAMPER is offline   Reply With Quote
Old 10-17-2015, 07:32 AM   #6
Did you stick the screwdriver in between the housing and lens or between the housing and ceiling?
Stephan
2016 Roo 21ss
Old 10-17-2015, 07:41 AM   #7
Iron Head you better Post a Pic of your lights before you BREAK a lens! Some are talking about Diff lights! Youroo!!
Old 10-17-2015, 08:29 AM   #8
ROCAMPER's Avatar
Housing and the ceiling. In the little slots for the screwdriver.
Old 10-17-2015, 11:29 AM   #9
Name:	ImageUploadedByForest River Forums1445099353.745755.jpg
Stephan
2016 Roo 21ss
Old 10-17-2015, 01:37 PM   #10
Use a paint can opener. Just put it in the slots and give it a twist. It works better than a screwdriver so you don't break the cover.
Mikewcrook is offline   Reply With Quote
led, light
