Old 09-19-2016, 12:32 PM   #1
urocav2001's Avatar
IRV 34
Hello, the dealer just installed a IRV 34 to replace my broken IRV 33, now I'm having issues with this one too, when I press zone three the radio just stays at a constant level, will not go up or down when I turn the volume know up or down, the other two zones work as they should
urocav2001 is offline   Reply With Quote
Old 09-19-2016, 01:02 PM   #2
Old Eeyore's Avatar
We only had 2 set of speakers installed in our camper (1 pair inside and 1 pair outside).
Unfortunately one inside speaker was zone 1 - left and the other was zone 2 - also left.
I'd check your wiring at the back of the unit to make sure the speakers you have are wired correctly. (Bet they ain't. )
2016 Roo 23IKSS / 2011 Tahoe
2011 Roo 21SS / 2011 Tahoe
2006 Bayside / 2006 4Runner
1999 SantaFe / 2001 Sienna
1967 Nimrod / 1998 Outback
Old Eeyore is offline   Reply With Quote
Old 09-19-2016, 01:20 PM   #3
karrun's Avatar
It's been a while since I installed my 34, but I seem to remember that once you set the correct source for zone 3, the volume knob should work to control it. Maybe you have another lemon?
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
karrun is offline   Reply With Quote
Old 09-19-2016, 01:22 PM   #4
karrun's Avatar
Found these directions: Your iRV34 has a unique function called Muti-Sourcing. This allows you to have zone 3 play from a different
source than zones 1 and 2 at the same time. To operate this function do as follows:
With radio on in normal mode you can turn any zone on/off with a quick push of any zone button.
To change source for zone 3:
Push and hold zone 3 button until the display reads Z3 followed by the current source that zone is playing.
Such as Radio/DVD/BT. Then push the mode button to change the source that is on zone 3. Now the volume
knob is controlling only the source of zone 3 playback.
To control the volume on zone 1 and 2:
Press and hold zone 1 for two seconds and now the volume knob is controlling zone 1 and 2 and all other
operations are back to normal.
M
2016 Roo 21SS
Mods so far:
Old 09-19-2016, 01:44 PM   #5
urocav2001's Avatar
Just did all of that, still won't go back to normal it will control the volume on just zone three if I go thru this process but then it goes right back to doing the same thing, won't allow you to control volume on all three sources at the same time?
Old 09-19-2016, 02:31 PM   #6
karrun's Avatar
Okay, now I'm not sure what you mean. You will be able to control Z3 volume while the input is set to Z3, and only Z3. You then have to change back to Z1 and Z2 to control their volume. You can't control all three zones simultaneously.
2016 Roo 21SS
Mods so far:
Old 09-19-2016, 05:40 PM   #7
urocav2001's Avatar
Oh ok, on my previous unit I could
Control all 3 at the same time with the volume know
Old 09-19-2016, 06:17 PM   #8
GracefulCamper
rocknroos's Avatar
During our recent trip out west we took a lot of movies with us to watch in the evenings. I have a brand new 2017 Roo 19 so it kind of surprised me to discover that the IRV would not play blu-ray discs. DVD's were ok but not the blu-ray. I got out the owners manual and it seems that it is not a blu-ray player. Did I miss something?
2015 Roo 17
2010 Lincoln MKT
rocknroos is offline   Reply With Quote
Old 09-19-2016, 07:04 PM   #9
Moderators' Assistant
bikendan's Avatar
As far as I know, only high end units have entertainment systems with blu ray capabilty.
RV Manufacturers don't feel most campers care about blu ray enough.
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 09-19-2016, 09:54 PM   #10
Zone 3 is considered separate, so no, zone 3 volume needs to be adjusted independent of Zone 1 & 2. It's a great feature! prior to that there were lots of complaints about outside either being too loud or not loud enough compared to inside. The other great thing with multisource is for example, you can listen to radio outside and TV or CD inside at the same time. Plus there is a phone app to control it all from your phone by the campfire via Bluetooth.
Ray
2017 Rockwood 2109S
Ram 1500
Me Her And a furry little dog
RandK-M is offline   Reply With Quote
irv
