Old 03-27-2014, 07:27 PM   #1
Is the Roo 19 too much for our GMC Acadia?
I am a newbie, of course, and am still so overwhelmed with all the trailer choices and information. I am at a loss of what would be the best hybrid for us. Can someone give me ideas of what the best hybrid to get would be?
First, we will be driving a GMC Acadia with the tow package and towing capacity of 5200 lbs. We are driving from Oregon through Utah into New Mexico and Texas and need a light hybrid trailer. We need a big enough trailer for 3 kids a cat and the only option we see is a hybrid. We have narrowed it down to the 17, 183 and 19. We like the 19 because it gives us the couch to sit on and it just seems more roomier. Each search gives me a different idea of what I can tow and different weights for the Roo's. The problem I am finding is that I keep reading that a fully loaded Roo is different than the weight that is on websites. Is that true? When a dealer says they have a fully loaded trailer does that mean it is heavier than what the said weight is from the manufacturer? We found a Roo 19 fully loaded for a really great price, but I am very worried that it will be over the actual weight and we will be kicking ourselves. I am now leaning toward the Roo 17 for the main reason of being scared that we are going to ruin our car with the 19 ft because with all the options it will be over what we expected, even before we load up our minimal stuff. We are very light packers and somewhat minimalist people, but stuff adds up quick no matter what.
Has anyone towed a 19ft with a vehicle similar to ours and was it fine? Is the 17ft doable with 3 kids and a cat? Any advice would be great.
marie_2014 is offline   Reply With Quote
Old 03-27-2014, 07:45 PM   #2
Broadway Joe's Avatar
The Roo 19 is listed at 3524 shipping weight add an additional 100 - 150 lbs for battery and propane tanks for an estimated empty weight of 3624 - 3649. The estimated max cargo capacity is 1182 for a gross weight of 4706. This puts you into the upper limit of your vehicle without you and kids and stuff loaded in your Accadia.
Broadway Joe is offline   Reply With Quote
Old 03-27-2014, 07:47 PM   #3
DaGrinch's Avatar
The dealer's definition of "fully loaded" is different than what we on the forum call "fully loaded".
The dealer's term is more consistent with what you would hear from a car dealer. Fully loaded means it has all the bells and whistles.
Here on the forum, we use "fully loaded" as having all the items in your camper you need for a camping trip; food, clothing, fully loaded propane tank(s), battery, full load in the fresh water supply, etc. This can add up to several hundred pounds in extra weight than what the yellow sticker on the camper lists.
As far as which hybrid - you need to give more information on your GMC. Does it have a tow package, size engine, what is the GVWR, etc?
My answer is just scratching the surface. You need to look at lots of stuff before you can decide if your GMC can tow a particular hybrid before you even decide if it will be possible once loaded with all your gear. The 19 might look good, but once you factor everything in, the 17 might be the only one feasible model.
Larry
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 03-27-2014, 07:59 PM   #4
davel1971's Avatar
kids require a lot of extra stuff to be brought along. Allow for more than you even think you will need. If it was just 2 adults, you might be able to do the 19
David & Lynn
Old 03-27-2014, 08:01 PM   #5
Camper Less Camping
Cajun Po-Boy's Avatar
Good thinking beforehand Marie....weights add up quick...If you shop by camper GVWR posted numbers (dry weight of rv + cargo capacity of rv) this will help you quickly narrow down what you can realistically tow with said TV.
If your tow vehicle (TV) has a max tow of 5200lbs, it's safe to bet you'll want your trailer GVWR to be 4250lbs or less...also remember your TV payload increases also as you had occupants and gear/aftermarket add ons to the TV itself.
It can sound confusing but once you work out the math, you'll ensure a better tow experience vs being overloaded and putting a strain on the TV and yourself!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 03-27-2014, 08:06 PM   #6
Engineer of Crazy Train
ChooChooMan74's Avatar
I was just reading your posts on the other forum. I think you will be ok, but the setup is not optimal...sorta like mine. There is someone on the Jayco forum towing a larger trailer with the Chevy version. Not sure if they have kids, but they are pushing the envelope. They say they aren't having issues.
Big thing, do everything safely. Get the best weight distribution hitch. Get the best brake controller. And, never be in a hurry. Our neighbors in Europe tow good size trailers with smaller cars with some success.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 03-27-2014, 08:08 PM   #7
bikendan's Avatar
your problem is using fictional "dry" weight numbers that manufacturers use to draw newbies into their web. NO trailer weighs its brochure/website "dry" weight.
the 3524lbs. number does not include the weight of so-called "options" that nearly all trailers have. awning, spare tire, oven, microwave, a/c, tv, water filter to name most of them.
plus it doesn't include the weight of a battery, propane, water and cargo, which has to be factored in to get a real world number.
i'm betting that the yellow sticker weight(which is what it really weighed when it left the factory)will be around 3900lbs.
so, loaded for camping, it'll easily weigh around 4500lbs., which is getting close to your Acadia's max of 5200lbs., IF it only has a 150lb. driver in it.
adding the weights of your family, WDH and cargo in the car, you could easily be near or at the max of your Acadia.
and as someone who lives out West and is always going over the Sierras, Siskiyous and Cascades , with my hybrid, i wouldn't want to be towing at max.
especially with a loaded SUV with a v-6 engine.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-27-2014, 08:16 PM   #8
Sgt. Schultz's Avatar
looking at the numbers for the trailers - the Gross Vehicle Weight (what should be the maximum trailer weight with all your stuff) all fall under the capacity of your vehicle and could be towed - you should know what the GVW of the vehicle is - all people/pets/camping stuff in the Acadia - once you have that you can then see if the on paper numbers work.
In any case these campers will all be on the high side of your towing capacity so you should not expect to win any races on the road, slow and steady will be the rule.
Depending on the age and options of the Acadia you may need new shocks, new tires, cooling system service, transmission service etc before heading out on this run.
Name:	roo weights.jpg
PT Avenger 33BHS-TE
GMC 2500HD SLE 4x4 Crew Cab 6.0 with 4.10's
Sgt. Schultz is offline   Reply With Quote
Old 03-27-2014, 08:26 PM   #9
Here is a Yellow Sticker for a Roo 183.
I think they will be fine. Not optimal. Good WDH like the Equal-i-zer P4 or the Reese Dual Cam. If they are 100 pounds over, whoopy doo.
Locomotive Engineer
Old 03-27-2014, 08:41 PM   #10
ChibullsAN's Avatar
X2 on the 183 for the family size and tow vehicle. Good fit.
2018 Rockwood Signature Ultralight 8329SS
ChibullsAN is online now   Reply With Quote
roo
