Old 01-04-2013, 08:04 PM   #11
ddemme's Avatar
Hey there! So, I did an image search for the 21SS and it looks like the antenna crank is in front of the kitchen which puts the head right between the fridge vent and the A/C. If FR had just placed it a foot or two further forward, you'd be fine .
So what to do... The wingman has the long center mast with two smaller cross-members. If it'll fit by cutting the center mast down no further than the inside of the first cross-member, you should be okay. Any more than that and it'll defeat the purpose.
The Jack replacement antenna head replaces the whole Sensar III head. Its 16" wide, but that's centered over the mast. So, you'll need 8" of clearance on either side.
There is also a complete Jack Antenna System and this appears to be ideal for your situation. The whole antenna will live above where the crank is and you won't have to crank up or down anymore. It also has a built-in signal meter, pretty cool.
I've been meaning to get a wingman for our 23SS, but the Jack System looks pretty awesome.
Hope this helps!
Drew & Kendra
Lucky & Bentley the camping dogs
2011 Ford F-150 SuperCrew EcoBoost w/tow pkg.
2012 Rockwood Roo 23SS
ddemme is offline   Reply With Quote
Old 01-04-2013, 09:38 PM   #12
ddemme - this sounds very helpful. Thank you for your time. So basically, sounds like I'm not getting out easy either way. great, FR.
If I need 8" on each side, maybe Jack will work. The next good weather day, I guess I'm back under the cover measuring. Thank you!
Roo-Woo is offline   Reply With Quote
Old 01-05-2013, 03:53 AM   #13
Witch Doctor's Avatar
Originally Posted by Roo-Woo View Post
Okay! Whew - thanks mtnguy - I think I'm getting it now. Sorry for letting my inner idiot take over.
The dimensions for the page you just sent me show to be 14" deep. So yes, what you called the "2 cross-arms" would be what's hitting my vent. And the Jack is only 12.5" deep. I don't really want to buy something, brand new, then have to start cutting parts off of it. Know what I mean? So that's why I'm trying to figure out if the Jack is a solution...
Thanks again!
I replaced my wingman with a jack. It is very small you can look up the dimensions. When it is lowered it sits on top of the arms that raise it. The reception is 100% better and also HD which a wingman is not. Just fits on the arms same as the old. I highly recommend it A 10 min job..... There are no cross arms to hit your vent.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 01-05-2013, 07:04 AM   #14
Takes longer to unpack the Jack and climbing on top of the trailer than it does to install the Jack. Pull two pins, hook up the coax and that's it! Maybe 3 minutes max.
Old 01-05-2013, 07:22 AM   #15
MtnGuy's Avatar
Huh ?? Winegard advertises the Sensar and Wingman as HD. The pictures looks pretty darn good on my TV.
Old 01-05-2013, 07:55 AM   #16
AquaMan's Avatar
If moving whole antenna toward the rotating base would help with clearances, you can cut the 2 mounting masts down. Simply cut off required length and redrill mounting holes.
BTW, I think I have a Jack antenna in my garage if you would want to try it.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 01-05-2013, 04:19 PM   #17
bikendan's Avatar
there's really no need for a "HD" antenna, it's a marketing ploy.
any HD tv can receive a HD signal through an antenna, even rabbit ears.
i know because i use rabbit ears for one of my HD tv's at home. just as good as the HD cable dvr, if not a little better.
it's the distance from the signal that is a big difference from the old analog signal. HD signals don't travel as far.
same thing goes for our HD tv with our old '06 Wingman antenna. no need for any special "HD" antenna.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-06-2013, 08:57 AM   #18
MtnGuy's Avatar
Agree, Dan. The TV picture in my camper was much better than my home TV on cable. After 1 too many price increases from the cable company, I discontinued the service, and put up an outside antennae......much better picture now.
Old 01-07-2013, 02:15 AM   #19
mtnguy, I do agree with you on Wineguard Sensar IV is uhf/vhf and HD. Sensar 1,2 and 3 are not. I do not know what your unit came with but mine was the 3. I can not find anywhere in Wineguard specs. saying that. Except for the Sensar IV. The Difference in price is like 3X'S higher for the Sensar IV? Which head do you think FR installed?.................The wingman has nothing to do with it except to pull in better reception and they do work great. On my unit the wingman would have hung over the side by 8" because of the placement through the roof....Ham Raido 101
Old 01-07-2013, 05:07 AM   #20
Many of the old analog TV stations were in the VHF frequencies (channels 2-13). All digital TV signals are in the UHF frequencies regardless of the channel number. The Wineguard antennas receive both VHF and UHF frequencies, therefore they receive HD signals. The Wingman attachment optimizes the antennas for UHF reception, so it improves reception. The Jack antennas were built from the start to receive UHF signals.
Note that almost all stations are broadcasting in the UHF frequencies with a digital signal, but whether they broadcast in HD or not is up to them. A TV with a digital tuner is required but whether or not it receives HD is up to you (or whoever supplied the TV).
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
antenna
