Old 06-08-2015, 10:40 AM   #1
wicked1's Avatar
Jack Pads what is everyone using
I am tired of carrying around wood blocks and bricks to support my jacks, so wondering what everyone uses, pictures would be helpful
Name:	ImageUploadedByForest River Forums1433778044.033193.jpg
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 06-08-2015, 10:44 AM   #2
Tinkerer and Putterer
Amazon.com: Camco 44505 Leveling Blocks - 10 pack: Automotive
HappyGuy is offline   Reply With Quote
Old 06-08-2015, 10:44 AM   #3
Boss Ox & Drovergirl
oxcamper's Avatar
I use the orange lego blocks -- BUT they are on top of a treated 2x8 square. I think the 2x8 helps distribute the weight on the ground better. It looks like you're pretty far extended by your pic, don't know what else. You're going to have to carry someting.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 06-08-2015, 10:53 AM   #4
wicked1's Avatar
I have a set of 10 but thinking of buying two more this way my Jacks are not all the way down and cutting my 2x8 into 4 squares to go under the plastic blocks
2015 Roo 23IKSS
Old 06-08-2015, 11:07 AM   #5
Have carried 10 of the yellow plastic blocks for years and very seldom have used them. I finally covered the top and bottom with alum tread plate and bolted them to the bottom of the jack pads. I extend my jacks as far as needed without additional blocks to get the jack legs as close to vertical as possible. Also have a set of electric jacks in front of the axle and homemade JT Strongarms.
ID:	79424   Click image for larger version
Name:	Front landing jak pad.JPG
ID:	79425   Click image for larger version
Name:	Rear stabilizer pad.JPG
ID:	79426   Click image for larger version
Name:	Front Landing jack pads.JPG
ID:	79427   Click image for larger version
Old 06-08-2015, 11:10 AM   #6
hammer55's Avatar
I have some of those plastic blocks also, but have not used them as yet
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 06-08-2015, 11:17 AM   #7
SternHappens's Avatar
I bought a set of the recycled tire rubber ones. More expensive than the yellow bricks, but I have been happy with them so far, seems to work much better on gravel of various sizes than the wood blocks or yellow plastic ones did.
2015 Georgetown 364TS, '05 TJ flat, or '14 Fiesta 5 spd w/Tandem Tow Dolly HDXL 8x10, & EZGO Customized Cart
Days Out '17-25{Days in Shop 141}; '16-59; '15-56.
2011 Flagstaff V-Lite 30WFKS '14-24, '13-33, '12-36, '11-29, '10-23.
SternHappens is offline   Reply With Quote
Old 06-08-2015, 11:21 AM   #8
CarolinaGirl's Avatar
We use the plastic leveling block as well. They are great for leveling our TT as well as putting under the jacks.
No Longer Newbies
2016 Trips:16 Nights:41
2015 Trips:13 Nights:29
2014 Trips:13 Nights:31
CarolinaGirl is offline   Reply With Quote
Old 06-08-2015, 11:23 AM   #9
rsdata's Avatar
I use 2x6 (1 1/2 inch high) lumber cut about 10 inches long. I have about 8 of these that I carry. They are strong and light. I also carry two 4x4 ( 3 1/2 inch high) by 10 inch to give me any added height on any one or two legs. These were scraps so they don't cost anything.
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 06-08-2015, 11:32 AM   #10
Wooden 2x6x12, 4of these screwed into a 12x12 pad 3" in. high
pdqparalegal1 is offline   Reply With Quote
