Old 10-26-2015, 03:14 PM   #21
Yes you need to winterize the outdoor shower because water will still get into it
Dinostop is offline   Reply With Quote
Old 10-26-2015, 03:48 PM   #22
urocav2001's Avatar
I have shower sprayer and yes you still need to winterize outside shower even if you haven't used it, the water still is sitting in the lines
urocav2001 is offline   Reply With Quote
Old 10-26-2015, 07:04 PM   #23
ColoradoRick's Avatar
Originally Posted by Ham Camper View Post
If you have never used the outside shower do you still need to winterize it?
Yes, there will be water in all the lines in the system.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 10-26-2015, 07:09 PM   #24
On the 23IKSS model, I have an inlet above my city water connection labeled antifreeze. I am assuming this was an effort by forest river to expedite the winterization process? The salesperson was no help and didn't know what it was for when I purchased the trailer. I suspect you can just attach a hose to the inlet on the trailer and pump your AF through this? I think there is also a bypass btwn the pump and water filter so you don't need to remove the filter? I removed mine last year anyway. I have mine in storage at the moment, but does this model have the Suburban or Atwood water heater?
JWHybrid2B is offline   Reply With Quote
Old 10-26-2015, 08:47 PM   #25
You're correct on how to use the AF connection, but incorrect on a bypass around your filter. You need to remove the filter and pump the AF through the filter housing. Some folks finds something like a bottle or can that fits in the housing so you don't have to fill the entire housing with AF.
This guy uses aquarium rock in his filter housing. See Post #5:
Stupid, Stupid, Stupid...
2011 Traverse LT, 3.6L, FWD
Old 10-26-2015, 10:53 PM   #26
I noticed one important step which was not mentioned in the original post. You need to flush the toilet to get the pink stuff into the toilet valve which could freeze and crack if you don't. Then pour a little more into the toilet bowl.
Hopefully you did this but I didn't see it mentioned.
Togger is offline   Reply With Quote
Old 10-27-2015, 07:05 AM   #27
Isn't there a second bypass around the water filter? I thought I remember seeing another valve next to the pump. I have so many water lines in that area it is difficult to see where they are all attached to.
Old 10-27-2015, 08:16 AM   #28
Sounds like a good job. Don't forget to release that check valve on the city water inlet. When I did this there was quite a bit of water n the line .
Brandon2
2014 2500TS Sunseeker
brandon 2 is offline   Reply With Quote
Old 10-27-2015, 08:20 AM   #29
Ham Camper's Avatar
Where is the check valve on the city water inlet?
Larry W8PO & Lori N8IHJ and Louie the wonder dog
2014 Surveyor Cadet 265RLDS
2015 GMC Denali HD
Ham Camper is online now   Reply With Quote
Old 10-27-2015, 09:03 AM   #30
Originally Posted by dogevans View Post
After winterizing, as much antifreeze as possible should be drained from all
of the lines. Leaving antifreeze "topped off" in the system is a bad idea.
When all liquids are cooled, they expand. You should always give liquids
a needed space for expansion. Antifreeze flushing purpose is just to remove
all of the water from the system. Once done, there is no need for antifreeze
to remain in the system.
Actually you are wrong. RV antifreeze will turn slushy and even freeze in very cold weather but will not expand in any way. Leaveing the lines charged with RV antifreeze will harm nothing.
Dan50 is offline   Reply With Quote
winter, winterize
