Old 10-27-2015, 10:52 AM   #31
ColoradoRick's Avatar
When I had the FR water filter, I found an empty but sealed bottle of Snapple was a perfect fit inside of the glass.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 10-27-2015, 05:33 PM   #32
The Check valve is inside the city water inlet. All one has to do is push their finger into the inlet and you will feel a button there, push it and you will hear the water pressure being released. Water flows back in to the fresh water tank or if you have the drain valve open , which you would, it will flow out on the ground.
Brandon2
Sunseeker TS 2014
brandon 2 is offline   Reply With Quote
Old 10-27-2015, 05:43 PM   #33
Send a message via Yahoo to Magee
Just got done winterizing
Originally Posted by Ford Idaho View Post
I would reinstall the low point caps to prevent any possible invasion of things that crawl on more than four legs.
X2
Magee is offline   Reply With Quote
Old 10-27-2015, 07:31 PM   #34
urocav2001's Avatar
Would their be water in there even if the mixes were blown out with air?
urocav2001 is offline   Reply With Quote
Old 10-27-2015, 07:34 PM   #35
Salem Cruise Lite Owner
Bushbunch's Avatar
I take my shower sprayer head off. I also tip my trailer toward the rear so the low point really is the low point.
Bushbunch is offline   Reply With Quote
Old 10-27-2015, 07:41 PM   #36
Flybob's Avatar
I remove both shower heads and drain them and leave them off. I also leave the antifreeze in the water lines. If you read the label on the antifreeze, you will note that the temp on the label is the temp above which it will not expand. It may turn to slush but will not expand.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-27-2015, 07:55 PM   #37
I read my manual for my 5er and it gives the option of either just blowing out the lines or using the af method. For the af method it says nothing about draining the af after pumping through the system and out each of the faucets.
Dinostop is offline   Reply With Quote
Old 10-28-2015, 06:49 AM   #38
No..the air pressure took care of it...your good !
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
Black is offline   Reply With Quote
Old 10-28-2015, 07:24 AM   #39
I have a couple of cups of left-over antifreeze and, this winter, I'm going to leave it outside when it's really cold to see how slushy it gets.
(The things bored campers do when they are housebound!!)
Rick & Karen
Monument, Colorado
Old 10-28-2015, 08:06 AM   #40
Bushbunch's Avatar
Did everyone see the warning label on the antifreeze? It's flammable! Also, I blew out my lines ONLY with a Layton and a Shasta AND a Fan for years and then, I had a low spot and yup, cracked my water line to the tub.
winter, winterize
