Old 03-13-2015, 03:22 PM   #1
Just got my First trailer...a Roo 19, what genny do I need?
Hello everyone.
I'm super excited. I just took the plunge and upgraded from tent caming to a 2011 Roo 19. I live in Phoenix and wanted to extend our camping season so something with hard walls and an AC is a must.
We pick it up on the 21st and and I've starting picking up odds and ends to stock it with, but the last big purchase would be a generator. Before everyone tells me, I know 2 Honda or Yamaha 2000 with parallel is the way to go. Unfortunately I don't have the money for that solution. So I need something cheaper.
I've started looking and can get a Champion 4000 used for 300, but will need to build a baffle box, but will still be on the annoying side of loud. I"ve also found a Champion 3100 new for 780. Its rated at 58db!. But at 3100 peak and 2800 watt rated.. can that push the AC, TV (25 inch), Lights, and Directv box? I would like to go with the quite option..but I can't buy top of the line.
Thanks for the help in advance. I've been "lurking" around this forum now for over a month to make sure the Roo is the way I wanted to go. This group is one of the major reasons I went Roo.
chuckythe2651 is offline   Reply With Quote
Old 03-13-2015, 03:38 PM   #2
Flybob's Avatar
What about fridge and water heater? Don't forget convertor, and CO/propane monitor. Biggest challenge is the AC start after initial start. A hard start capacitor can help but you are going to have to pick and choose what you run.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-13-2015, 03:53 PM   #3
TURBS's Avatar
Look here.
minimum size generator for pup
Old 03-13-2015, 05:23 PM   #4
bikendan's Avatar
Chucky, the Champion 3100 will run everything including the a/c, on your Roo.
it's a great choice if you can't afford the H or Y units.
you may have to put the fridge and WH on propane, to run the a/c.
you'll just have to test it out first and see what can run when the a/c is being used.
but i have run my Roo's a/c on my Honda 2000. course that wasn't at elevation.
by the way, Costco has a black edition of the Champion 3100, for $699.99, til the end of March.
item #941930.
GREAT PRICE! along with Costco's great return policy.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-13-2015, 05:35 PM   #5
HONDAMAN174's Avatar
A good question to ask yourself is where will you be camping. If you will staying at full service CG's you won't need a genny. For dry camping, will you be doing it during the heat of the summer or will a/c not be needed. Our dry camping spot is at altitude so we only bring one honda 2000 to recharge off of. We also have a second unit to parrael but have not had the need for it yet.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 03-13-2015, 06:44 PM   #6
Awesome help guys! We will be mostly boondocking ( this is my way of having a house on the lake without paying the 300 - 900k it normally takes)
I've spent all day reading up on this stuff and it definitely looks like I want an inverter generator and at $700 that 3100 seems to be the sweet spot for me. Plus it wont get me in hot water with my neighbors!
Old 03-13-2015, 08:45 PM   #7
It sounds like it fits your needs but be aware that it weighs over 80 pounds. That's a lot to lug.
- 1969 Coleman Williamsburg (with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 1999 Chevrolet Astro
- 2005 Dodge Durango Limited 4x2 5L V8 Hemi
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
chriscowles is offline   Reply With Quote
Old 03-14-2015, 12:32 PM   #8
TGR
TGR's Avatar
The biggest problem with the smaller generators is their run time. The Champion 3100 runs 8 hours at 25% load. That may be to short for overnight operation if your A/C is running, which will reduce the run time.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
Old 03-14-2015, 02:18 PM   #9
Originally Posted by chuckythe2651 View Post
Hello everyone.
I have a champion, my only complaint it's noisy. The Honda's are a lot quieter.
Stovebolt is offline   Reply With Quote
Old 03-14-2015, 02:20 PM   #10
bikendan's Avatar
That would only be an issue if you're boondocking, since campgrounds don't allow running generators overnite.
roo, trailer
