Old 08-22-2015, 08:03 AM   #11
Alleged curmudgeon
Vern's Avatar
Originally Posted by Oaklevel View Post
We have used a ceramic heater (got our last one at Walmart) in our campers for years they work great, but use common sense when using them as you wood at home.
x2...When spring/fall camping in Michigan, if we have a "cool" night and don't want to run the furnace, we often run only a ceramic heater, on low, just to take the sting out of the air.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34)
Vern is offline   Reply With Quote
Old 08-22-2015, 08:18 AM   #12
We use the Eden Pure exclusively, it doesn't get hot to touch and is remote controlled. On real cold nights in FL, I just move it over to the furnace intake and turn the blower on the furnace (burner not on) and let the furnace blower circulate the warm air throughout the 5er and basement.
Old 08-22-2015, 08:22 AM   #13
Alleged curmudgeon
Vern's Avatar
Thanks for that tip, OC. That is a much better approach I'd not thought of for balancing things out in the TT.
Lee
Old 08-22-2015, 08:26 AM   #14
You do have to put a separate switch on the furnace blower to make it run without the burner being on.
Old 08-22-2015, 08:31 AM   #15
Alleged curmudgeon
Vern's Avatar
Yep, makes perfect sense. I should have thought of that, but then I'd be putting you out of a job.
Lee
Old 08-22-2015, 02:26 PM   #16
I'm sorry OC, but did you just say "real cold nights in FL?"
2007 Dodge RAM 2500 5.9L
2010 Wildcat 30-LOFT
bradleyr001 is offline   Reply With Quote
Old 08-22-2015, 02:38 PM   #17
I certainly did, on more than one occasion it has gotten down in the mid-lower 20's which is "real cold" for FL. We lived in northern IL where it stayed for days in the 0 to below 0 where we lived in an 8'x32' house trailer in Moline, IL
Old 08-22-2015, 03:03 PM   #18
Just pokin' fun at ya... Most people don't relate "real cold" with Florida, but you are correct, it has it's moments of cold and real cold weather.
Old 08-22-2015, 08:49 PM   #19
X2
drhroo is offline   Reply With Quote
Old 08-22-2015, 11:25 PM   #20
Originally Posted by HONDAMAN174 View Post
And a little buddy heater when dry camping:
Mr. Heater F232000 MH9BX Buddy 4,000-9,000-BTU Indoor-Safe Portable Radiant Heater https://www.amazon.com/dp/B002G51BZU..._PL-1vb0F94KP5
You might want to Make Sure that you Mount that Little Buddy closer to the Floor than your Sleeping Bunks.
Approved for indoor/outdoor use; clean-burning; nearly 100-percent efficient
Auto shut-off if tipped over, if pilot light goes out, or if detects low oxygen levels
Low Oxygen Levels are just a "Proxy" (and a rather poor one) for Carbon-Monoxide and Carbon Dioxide Sensors. Both of those Deadly Poisons produced by your Propane Burning Heater are Heavier than Air AND can reach Dangerous or even Deadly Levels while Oxygen Levels are still "almost Healthy".
This is one of the reasons that Carbon Monoxide / Propane Sensors are Mounted as Low as Possible to the Floorboards.
Pup: '11 HW-296
TV: '09 RAM 1500 Hemi 4x4 CC
seigell is offline   Reply With Quote
heater
