Old 09-09-2014, 09:36 PM   #1
Question LED Ceiling lights
Our first year with our 2014 Roo and would like to clean the lens of the ceiling lights. How do you remove the lens covers?
Thanks Papa Smurff
Pappa Smurff is offline   Reply With Quote
Old 09-13-2014, 07:39 PM   #2
rsdata's Avatar
Remember seeing the bottle openers, that were made of a loop of wire forming an opener on one end, and a handle on the other? Think of a toy soap bubble plastic piece in the jar... hard to describe, but mine came from a paint supplier years ago, to use to open a can of paint, and then drink a beverage when you were done. At any rate, the handle end has a small hook, very small hook on the end. It is the perfect size to fit into four small indentations on the light housing, near the ceiling two on each side near the ends. Push in with that small hook and pry down and the lens cover comes off.
Old 09-13-2014, 07:53 PM   #3
mark0224's Avatar
If they are like these something thin like a butter knife slid between the lens and the white band that the switch is on give a slight twist of the knife and the lens will slide. It only moves a small amount then the tabs that hold it on will let it come off.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
led, light
