Old 04-28-2013, 12:16 PM   #11
Fulltime family RVer
Two- another brand for between the wheel chocks are Rotochoks.
Old 04-28-2013, 01:46 PM   #12
When using the Lynx do you top them with something smooth?
2013 Flagstaff 27RLWS
2014 Ford F150 Ecoboost
30 nights in 2015 so far
roanmountaincampers is offline   Reply With Quote
Old 04-28-2013, 01:58 PM   #13
Triguy's Avatar
I think that is a personal preference.
There are caps which are designed to fit on top of the levelers but I don't use those for my tires. My levelers will be stacked in an alternating and interlocking floor and I just drive on top of that when in place. See the picture below.
I use the caps for the top layer for my power jack and stabilizers. I think I only have four so one stab is left out. They're not that useful IMHO for the tires but they might provide a little more stability for stabs and the jack.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-28-2013, 05:20 PM   #14
If you look at the to pic in Triguy's post above, and imagine for some reason that you need to go higher than 3 levels, you'll realize that you will have to go out farther on the bottom layer and subsequent layers. I picked up a tip somewhere (maybe another post on this forum) and I cut one of my squares in half. Then, instead of a full square at (say) the bottom right end, I'd put a 1/2 square. Then for the 3rd row, I'd use the other 1/2 and put the 4th row above it. Saves a couple squares overall, which is useful since going higher is already using up more squares. And since you ususally want to pick up both tires, you have to go longer than shown in Triguy's pic (i.e. instad of 3 on the bottom row, you might need 6).
Old 04-28-2013, 08:03 PM   #15
Engineer of Crazy Train
ChooChooMan74's Avatar
I would get the legos, and get at least 24. I found out 16 wasn't enough.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 04-28-2013, 09:56 PM   #16
Herk7769's Avatar
I use 12x12x2 pressure treated wood boards for support and leveling.
If I need to lift higher than 1 1/2 inches I use the "Leggo" levelers above that.
This way the plastic building blocks have a solid base and they don't break on gravel or sink into soft dirt (and sometimes freeze in the mud).
The wood is easier to clean. I carry 8 boards and 16 Leggo blocks (2 bags) with 4 top sections. 2 top sections fit in each bag.
HAM CALLSIGN - KC3FFW
Old 04-28-2013, 10:14 PM   #17
I carry a 6-foot 2x12. and just add wooden shims under it to create a ramp of whatever height is required.
One note, if you have rubber torsion axles, you do not want to have one much higher than the other. A few inches is ok, but much more and you put too much weight on one.
Suspensions that use regular springs balance out the load even if the axles are at much different levels.
bakken is offline   Reply With Quote
Old 04-29-2013, 06:28 AM   #18
Herk7769's Avatar
This is very true. While having/changing a flat with twice its normal load on the "good" axle is designed into the load rating of the axle, repeated overloading the torsion axle will certainly damage it.
Old 04-29-2013, 07:04 AM   #19
Experienced Newbie
As others have already stated, get the Lego style blocks. I personally prefer the Ramble yellow blocks. They have a flat top but still lock together. Camping World has these on sale regularly, plus they make a wheel chock that fits these blocks
2011 Silverado CC/SB
2014 Cougar 31SQB
mhartzel is offline   Reply With Quote
Old 04-29-2013, 07:24 AM   #20
While I know many say that you can lift the camper to change a flat by running the good tire up on a ramp, thus supporting the entire load on that sone tire, the thought of overloading that axle by 175% still concerns me.
I think I will stick with jacking on the frame, and being careful when using ramps.
