Old 08-19-2016, 03:01 PM   #1
Lights under cabinet b(Roo 23WS)
A new mod I just did. I installed reading lights under the cabinets (over the U-shape table).
I had to lift the bottom panel of the cabinets to get to the wires. There are two panels and the wires are tucked between the two......Anyway, once I found a positive and negative wire, it was a breeze.
I do have to say the bulbs that came with the lights (1056, I think) were producing a lot of heat, and my DW mentioned it to me after touching the cabinet bottom panel. I ordered LED equivalent from eBay, and these don't produce any kind of heat.....GREAT!
Drenjoey is offline   Reply With Quote
Old 08-19-2016, 06:22 PM   #2
This is just another issue I have with this website! Now I have another item to add to my "to do" list.😄
Nice job with the lights!
2015 ROO 233S
2013 F150 Eco Boost
1Roo4Ladds is offline   Reply With Quote
Old 08-21-2016, 05:19 PM   #3
What's it take to lift the cabinet bottom? (And I assume you meant you lifted the TOP panel of two that make up the BOTTOM of the cabinet?
2011 Traverse LT, 3.6L, FWD
Old 08-21-2016, 05:43 PM   #4
Kind of easy.....In the upper cabinets, remove the two moldings that holds the piece of board behind the electric switch panel, and then start lifting the top bottom panel starting from the left .....Welcome to a world of wires !!!
Old 08-21-2016, 06:04 PM   #5
Drenjoey:
My Roo is gone, I'm in a Mini Lite now, so I'm guessing I don't have quite the same setup as yours. I'm more interested in the moldings and the lifting. Are you saying you just pried out the molding and lifted the panel? The molding was stapled/nailed? There was nothing glued that you had to deal with?
Old 08-21-2016, 07:56 PM   #6
Great mod!
joinco70 is offline   Reply With Quote
Old 08-22-2016, 03:10 AM   #7
Drenjoey:
As you said: pried and lifted.....no glue.
Old 08-22-2016, 08:38 AM   #8
Thanks. I'm surprised about no glue, but maybe it's just the bottom panel that's glued. Would make some sense, so you could still get to the wiring from the top panel. But I don't see a lot of sense in the things on these TT's!!
Old 08-22-2016, 05:08 PM   #9
Nice! Thanks for sharing. We have the exact same model and want to do the same.
HappyTrails8888 is offline   Reply With Quote
Old 08-22-2016, 05:13 PM   #10
SeaDog's Avatar
Nice job looks good
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
SeaDog is online now   Reply With Quote
light, roo
