07-05-2019, 08:23 PM
Looking for piano hinge
I am rebuilding the front bunk on my 2010 Roo. I damage the piano hinge during the rebuild and I can't find the exact replacement online. Any help would be appreciated.
Brad
07-05-2019, 08:26 PM
Have you tried FR parts department?
07-05-2019, 08:29 PM
I have not. I will check there.
Thank you
Any Lowe’s or Home Depot have selections of piano hinges.
TV - 2020 RAM 3500 Mega Cab SRW with 6.7 Cummins HO & Aisin 6 spd, 4k payload, 23k towing
2002 GMC Yukon XL 2500, 8.1 liter (496ci), 4L85e & positraction with 3.73 gears
TT - 2013 Dutchmen Aspen Trail 3130 QBS
Great bourbon-just about any of San Diego’s craft beer
07-05-2019, 08:32 PM
What does FR abbreviate for?
07-05-2019, 08:34 PM
Coach
FR=Forest River
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
07-05-2019, 08:36 PM
Amazon, EBay did you Google Piano Hinges???
Heavy Duty 2" x 48" Stainless Steel Piano Hinge - .060" Thick - ¾" S.S. Screws Included https://www.amazon.com/dp/B07D7Y4YXR..._-R.hDbNF1PGRR
John
People sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf.
99 F350 Dually 7.3L
07-05-2019, 08:49 PM
Also available at places like Ace Hardware, Do-it-Best and HD.
On a previous TT I tossed the two factory installed door hinges at the head of the bed and got a length of piano hinge at HD.
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
07-06-2019, 01:33 PM
I replaced the crappy loveseat in the front of my 19" Aspen Trail with a full eight-foot Murphy bed which folded down for use at night. The underside was just finished oak plywood, and when folded up looked like a finished cabinet..
The best piano hinges were available from actual building supply places, or cabinet shops. Most in Lowes or HD are cheap plated ones from China. I got a full-length stainless steel one which was about 1 inch wide, for less than $40.
07-06-2019, 06:06 PM
Senior
FYI hinges are normally measured with the leaves opened
07-06-2019, 06:15 PM
Yep, first thing I would have done!
07-07-2019, 05:12 AM
McMaster- Carr has a large selection
2013 Rockwood 2504
2015 Silverado 1500 4x4 Z71 Double Cab
Diablo and Lew Custom tuned
Tony & Catnis, campin' kitties
07-07-2019, 07:34 AM
Forest River, as in Forest River Forum!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
07-07-2019, 07:53 AM
Your local Home Depot will have 2 or 3 colors and several lengths in the hardware department. Any associate or the Home Depot app will take you right to them.
'19 Chevy Colorado Z71 4x4 Crew Cab
'17 Salem Cruise Lite 232RBXL
Mickey the Rescue Project Schnauzer
Days Camped: '17-39, '18-61, '19-64, '20-38
07-07-2019, 01:10 PM
If you search on HD's website, either home or phone, under "Pick Up In Store Today," it will tell you the aisle and bay where it is located. Don't need an associate.
Lowe's does the same thing. It's actually easier to see on their website.
2011 Traverse LT, 3.6L, FWD
07-07-2019, 02:56 PM
I buy piano hinges on eBay and Amazon. Good selection and you can find stainless steel ones that way too.
07-08-2019, 06:55 AM
Yes and be sure to use stainless steel rivets as well... If you don't the dissimilar metals of the hinge and rivets cause corrosion.
Gerry Z
2018 Forest River Heritage Glen 272RL
2018 Ford F150 Lariat 3.5 Ecoboost Max Trailer Package
Curt Trutrack WDH
HD Roadmaster Active Suspension
3200 Firman Generator/Inverter
07-08-2019, 09:20 AM
I always use stainless rivets anyway when I use them. Most of the times when I put fasteners on the RV, I use stainless screws. Aluminum rivets are even fine with stainless unless its in a moist environment and even then its usually fine. Aluminum and stainless touch each other all the time on marine motors and drives.
