04-18-2015, 09:21 AM
Low level water outlet
Can someone tell me how to open the water outlet. We have tried turning and pulling and it doesn't move. I need to dewinterize.
04-18-2015, 09:27 AM
If you're talking about the low point drain on your fresh water tank. It turns. May be a little stiff sitting over the winter.
2017 GMC Yukon
2018 Roo 23 ikss
04-18-2015, 10:23 AM
Are you asking about the fresh water tank drain or the hot/cold water low point drains?
Dave
04-18-2015, 11:10 AM
Have you checked the nozzle for obstructions? I had a problem draining my fresh water tank only to find that a Mud Dauber had been busy and had it filled with dirt.
04-18-2015, 12:13 PM
On the side of the trailer above the wheel it says low point drain. It's near the shower outlet. Thanks
04-18-2015, 01:40 PM
The low point drains in the plumbing are just caps that are threaded on... righty-tighty, lefty-loosey (although some people replace them with ball valves so there are no caps to lose).
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
04-18-2015, 02:06 PM
They are crazy tight. I couldn't remove mine last fall when winterizing, so I cut them off and replaced them with a pex ball valve like this:
I live with fear every day, and sometimes she lets me go fishing.
2019 Surveyor 251RKS
2008 Ford Expedition EL
04-18-2015, 03:03 PM
If it's the kind I'm thinking, the barb to male NPT piece has a hex section that you could put a wrench on then water pump pliers on the cap side...should come off.
Dave
04-18-2015, 03:25 PM
I had to use channel locks the first time. I just hand tighten them now.
B and B
04-19-2015, 07:52 AM
Chanel locks and a wrench. First time
04-19-2015, 12:40 PM
X2!
2011 Traverse LT, 3.6L, FWD
04-19-2015, 02:25 PM
X3!
04-25-2015, 08:15 PM
Still can't get the darn thing open. How many times do I turn it to the left and how hard should it be to pull it out? I don't know why this is such a big problem! Thanks again ....
04-25-2015, 08:23 PM
If I remember you just turn tell the water starts draining. No pulling
04-25-2015, 08:34 PM
You haven't pressurized your system have you? If you have you will need to release the pressure by opening the relief valve on the water heater or open a valve on the sink. That would make it hard to remove.
2014 Chevy Silverado
2011 Rockwood Roo 233S
04-25-2015, 08:37 PM
If the cap is turning, but not coming off then you are turning the whole fitting that is hooked to the hose. Put a wrench on the fitting to hold it in place and then try turning the cap. It should come off then. The second year when I went to drain my fresh water tank I unscrewed the whole fitting out of the tank without removing the cap. I removed the cap & then screwed the fitting back in. Hasn't been a problem since.
04-25-2015, 08:49 PM
If they look like this . . . then
04-25-2015, 09:15 PM
^^x2
04-26-2015, 07:01 AM
Thanks for info. Walk though didn't include this, or many other details!
04-26-2015, 07:30 AM
Not a real surprise, no dealer can know everything about every unit they sell.
Low point drains were pointed out and there has been no issue with pulling the caps off.
If mine were that hard to remove I would have cut them off by now.
