Old 10-22-2012, 12:02 AM   #1
BeagleIL's Avatar
Low point drains...
Can anyone explain why they would switch to drain caps instead of using a valve? I seriously had to use pliers on them to get them off today. Along with a wrench to keep the stub from spinning in the PEX.
Mark, Jenny, Adam & Lucy
2013 Rockwood Roo 233S
2015.5 Silverado 2500HD CCSB with Duramax/Allison
BeagleIL is offline   Reply With Quote
Old 10-22-2012, 12:10 AM   #2
I was wondering that mysekf today. Not sure why they did that, but I'm thinking it had something to do with money! I plan on installing valves in the spring.
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
Old 10-22-2012, 03:04 AM   #3
bikendan's Avatar
Cost!
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-22-2012, 04:03 AM   #4
cardinal4fun's Avatar
My thoughts would be one the cost of the value, which when you would buy cases of them really makes no sence. The other reason may be when building the unit and pressure testing the lines they values just slowed up the process. Or to stop people at campgrounds from going around and opening up values for the fun of it.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 10-22-2012, 06:58 AM   #5
realebill's Avatar
first thing i did on my rig was to install valves on the low point drains. easy and inexpensive ! second thing was to replace all the steel screws on the outside with stainless steel screws.this to me is one of the most blatant cost cutting moves a manufacturerer can make.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 10-22-2012, 07:28 AM   #6
lindy's Avatar
x2 on realebills solution, went to Lowes and got 2 "Ball Valves" now all it takes to drain the trl is a 90 degree turn of 2 valves, much easier!
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 10-22-2012, 09:12 PM   #7
What size valves?
Old 10-23-2012, 07:15 AM   #8
lindy's Avatar
rockfordroo; if memory serves me they're 1/2 NPT. Take the cap with you to be sure.
F.R.O.G. member
Old 10-23-2012, 07:37 AM   #9
Fire Instructor's Avatar
1/2" NPT? Mine are 1/2" PEX, which requires a PEX crimping tool. A decent PEC crimper can be bought for $30+/-. I needed to make a repair, so I bought the crimper, a couple of feet of PEX pipe, a handful of various fittings, elbows, and valves, and for less than $75 I made my repair, and I've got a "PEX Toolkit" (which I've since used to re-plumb my previously difficult to access water filter AND make a repair on another campers rig) all for less than what a service call would have cost for the original repair!
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
