06-29-2014, 12:24 PM
Low Pressure Propane Stove
I'm looking for a propane stove to hang on the side of the trailer (instead of the BBQ). Sometimes it will be handier than a BBQ. Dealer said it must be a low pressure unit. Any suggestions ???
06-29-2014, 01:53 PM
I use this. I bought a quick connect hose so I can plug it into the camper and then I set it on a table. The quick connect hose does not have a regulator and the stove will run off the low pressure connection on the camper side. You could also make a stand to go on the side rail if you did not want to use a table.
Actually you can do this with any camp stove that has the regulator attached to the hose.
the only retail stove i know, that will work right off, are the Camp Chef stoves.
unless you can find some of the low pressure stoves that popups come with.
06-29-2014, 02:11 PM
I plan to modify an old gas connector/regulator for my standard 2-burner Coleman propane camp stove using the approach described below. By having both a modified low-pressure quick connector a standard high-pressure regulator I can also use it normally with a disposable bottle or with a tree on a large propane bottle.
I may or may not add fittings to slide the Coleman stove onto the RVQ stand but, personally, find that a bit high for my comfort. I'm looking for an acceptable table to use for that purpose, today. I don't want a full-blown camp kitchen.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
06-29-2014, 02:36 PM
Good video! Informative.
06-29-2014, 10:28 PM
The OP of the video describes the Coleman fittings as "proprietary". I can't refute that but think they're not. Instead, they may be "fine-threaded", reference to which I've seen in my search for quick-connect fittings. If so, you won't find those at a big-box home store or your corner hardware store but you might find them at a commercial plumbing supply shop.
I'm fortunate in that the old regulator for my Coleman stove is threaded at the regulator end, not welded as some appear to be. The aluminum pipe is fine-threaded into a brass fitting that has a standard 1/8" male brass thread (or however that's properly described.)
Home Depot had a 1/8"-to-1/4" female-to-female adapter that fit. The 1/8" end fits the regulator brass fitting; the 1/4" end will fit a Camco quick-connect fitting ordered online.
I bought a new Coleman high-pressure regulator to replace the one I hacked, while I was at it. Now I'll have both.
06-30-2014, 12:36 PM
I did the mod to my Coleman grill and love it. Got most fittings from a small hardware store. Had to get the quick connect online because the one they had was the wrong type.
'18 Ford F250 Lariat Super Crew
'22 Rockwood 2608BS
Previous '17 Grand Design Imagine 2800BH, '13 Rockwood Roo 21SS
06-30-2014, 04:20 PM
I rigged up gas connections/adapters for my outdoor stove from my last Coleman popup and for a Coleman green camp stove. Both would not create a large flame when turned on high due to stove design (Even with out a regulator connected). Thanks for the link to the Camp Chef stove. That will be my next addition.
Big Johnny
2014 Chevy Silverado 1500
2014 Micro Lite 23LB
Are we having fun yet??
07-02-2014, 08:46 AM
Grege, I did the same. However I had to file down the end of the quick connect nipple to get it to fit with the hose from the camper. Following that, I discovered that the connection isn't sealing, as evidenced from a soapy water test.
Where did you order the fitting from and do you have a part #?
-t
07-02-2014, 10:28 AM
Originally Posted by wmtire
Good to know for BBQs. Have you come across any stoves?
07-02-2014, 10:34 AM
Aaah, understand now. The eyes read it, but the brain didn't compute.
2011 Flagstaff 831 RLBSS
07-02-2014, 10:44 AM
Wmtire - no seriously the info was great. I will upgrade my BBQ with the first one you showed in your list. Didn't realize my options there. My challenge is sometimes the stove gets more use than the grill.
07-02-2014, 01:42 PM
-t
I got it from www.rvparts.com. Part number is QDGMRVN44M and mfg is Fairview Fittings.
'22 Rockwood 2608BS
07-02-2014, 10:20 PM
I just got my parts from Amazon. Unfortunately, the replacement Coleman regulator is slightly different from my old one. I can't use the new one with a disposable bottle on my stove. Searching Coleman.com for the correct replacement part shows a price of $40, if it's even available. Other sites show it back-ordered.
The alternative, now that I have the new regulator (and ripped it off the card to reveal my error), is to buy a new stove for $10 more than a new regulator for my old stove. Living in Florida during hurricane season, I need a backup kitchen to use at my house, so I guess I'll be doing that sooner or later.
I'll use the old one as my low-pressure stove on the trailer, until I get the new one. Then I'll convert my extra (new) regulator to work with the low-pressure quick connect and sell or donate the old stove. I don't need two.
07-02-2014, 11:46 PM
There's hope. Camco makes a 6' hose with a regulator on one end and a female quick connect on the other. It's half the price of a replacement regulator from Coleman and fits the propane distribution post I already have.
Having converted my 2-burner stove to quick connect for use with the trailer, now I can look like I planned it this way all along. ;^)
Of course, now I have a spare regulator that doesn't fit anything I own ...
07-03-2014, 06:54 AM
When I purchased our 2012 ROO 23SS, I substituted the grill for a stove. A Suburban 2 burner low pressure stove was provided.
You may wish to have your dealer source and price it.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
07-04-2014, 07:39 PM
Okay, that didn't work. When connected to the standard disposable bottle with a regulator the flame is large and hot. When connected to the low pressure hose on the camper with no apparent regulator inline, the pressure is extremely low, as is the flame.
The stove end of the connector has what appears to be a Schrader valve. That makes sense as a safety device to prevent a bottle from being vented to atmosphere without being connected to the stove.
Perhaps there's a regulator inside? Does anyone have any suggestions?
07-04-2014, 08:13 PM
I gas up my Coleman like this.
I have a 3 and 5 foot hose for the grill and a camp stove.
Both feed off the gas tree.
07-04-2014, 08:50 PM
Thanks for the info I've got a Coleman stove I wanted to hookup, I also want to make a tee so I can run 2 units , stove and a Grill.
Think about things before you do them make life easier not harder.
