Old 06-29-2014, 12:24 PM   #1
CDNWhiskey's Avatar
Low Pressure Propane Stove
I'm looking for a propane stove to hang on the side of the trailer (instead of the BBQ). Sometimes it will be handier than a BBQ. Dealer said it must be a low pressure unit. Any suggestions ???
CDNWhiskey is offline   Reply With Quote
Old 06-29-2014, 01:53 PM   #2
I use this. I bought a quick connect hose so I can plug it into the camper and then I set it on a table. The quick connect hose does not have a regulator and the stove will run off the low pressure connection on the camper side. You could also make a stand to go on the side rail if you did not want to use a table.
Actually you can do this with any camp stove that has the regulator attached to the hose.
grubbster is offline   Reply With Quote
Old 06-29-2014, 01:53 PM   #3
bikendan's Avatar
the only retail stove i know, that will work right off, are the Camp Chef stoves.
unless you can find some of the low pressure stoves that popups come with.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-29-2014, 02:11 PM   #4
I plan to modify an old gas connector/regulator for my standard 2-burner Coleman propane camp stove using the approach described below. By having both a modified low-pressure quick connector a standard high-pressure regulator I can also use it normally with a disposable bottle or with a tree on a large propane bottle.
I may or may not add fittings to slide the Coleman stove onto the RVQ stand but, personally, find that a bit high for my comfort. I'm looking for an acceptable table to use for that purpose, today. I don't want a full-blown camp kitchen.
- 1969 Coleman Williamsburg (with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 1999 Chevrolet Astro
- 2005 Dodge Durango Limited 4x2 5L V8 Hemi
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
chriscowles is offline   Reply With Quote
Old 06-29-2014, 02:36 PM   #5
CDNWhiskey's Avatar
Good video! Informative.
Old 06-29-2014, 10:28 PM   #6
The OP of the video describes the Coleman fittings as "proprietary". I can't refute that but think they're not. Instead, they may be "fine-threaded", reference to which I've seen in my search for quick-connect fittings. If so, you won't find those at a big-box home store or your corner hardware store but you might find them at a commercial plumbing supply shop.
I'm fortunate in that the old regulator for my Coleman stove is threaded at the regulator end, not welded as some appear to be. The aluminum pipe is fine-threaded into a brass fitting that has a standard 1/8" male brass thread (or however that's properly described.)
Home Depot had a 1/8"-to-1/4" female-to-female adapter that fit. The 1/8" end fits the regulator brass fitting; the 1/4" end will fit a Camco quick-connect fitting ordered online.
I bought a new Coleman high-pressure regulator to replace the one I hacked, while I was at it. Now I'll have both.
- 2000 Coleman Mesa
Old 06-30-2014, 12:36 PM   #7
grege's Avatar
I did the mod to my Coleman grill and love it. Got most fittings from a small hardware store. Had to get the quick connect online because the one they had was the wrong type.
'12 Ford F150 Lariat Super Crew
'17 Grand Design Imagine 2800BH (Previous '13 Roo 21SS)
2016 Nights camped: 7
2015 Nights camped: 21
2014 Nights camped: 18
2013 Nights camped: 26
grege is offline   Reply With Quote
Old 06-30-2014, 04:20 PM   #8
I rigged up gas connections/adapters for my outdoor stove from my last Coleman popup and for a Coleman green camp stove. Both would not create a large flame when turned on high due to stove design (Even with out a regulator connected). Thanks for the link to the Camp Chef stove. That will be my next addition.
Big Johnny
2014 Chevy Silverado 1500
2014 Micro Lite 23LB
Are we having fun yet??
tipakajohn is offline   Reply With Quote
Old 07-02-2014, 08:46 AM   #9
Grege, I did the same. However I had to file down the end of the quick connect nipple to get it to fit with the hose from the camper. Following that, I discovered that the connection isn't sealing, as evidenced from a soapy water test.
Where did you order the fitting from and do you have a part #?
-t
the8re is offline   Reply With Quote
Old 07-02-2014, 09:33 AM   #10
wmtire's Avatar
The RVQII
RVQ II Grill Portable RV Grill $229 with FREE SHIPPING except HI, AK & Canada
Camco Olympian
Amazon.com: Camco 57305 Olympian 5500 Stainless Steel Portable Grill: Automotive
and Sidekick
Amazon.com: Outdoors Unlimited RVAD400 Black Finish Sidekick Grill: Automotive
are all grills made to utilize the RV's low pressure gas line that are downstream of the propane tanks regulator
My RV came with the sidekick grill. I had to buy the regulator/adapter that let's you also use it with high pressure 1lb propane bottles. I needed this, cause my sidekick does double duty and I use it on the pontoon boat as well. It appears from the Amazon link provided above, that their sidekick already comes with with this adapter (which you may or not ever need)
Someone stop me! I can't stop buying camper stuff!!!
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
pressure, propane
