Old 06-22-2013, 11:13 AM   #1
redsuspenders's Avatar
Low water flow
Whether we are on supplied water, or using our fresh tank and pumping, we have low flow from the sinks and the shower.
I thought with the kitchen it may be calcium build up so I changed the sink aerator. No help with that.
Not sure what else could be causing this issue.
Any ideas?
2011 Roo 21SS
2012 Ram quad cab
redsuspenders is offline   Reply With Quote
Old 06-22-2013, 12:09 PM   #2
Arn
Arn
Do you have an inline water filter? Could be time to change it or remove it altogether.
Arn
Arn is offline   Reply With Quote
Old 06-22-2013, 01:01 PM   #3
CDNWhiskey's Avatar
When you run the taps with the aerator removed you still don't have pressure? The little white disc in the aerator can easily get plugged but if you don't have flow with them removed its obviously not them. Time to search the hoses for kinks and pinches too
CDNWhiskey is offline   Reply With Quote
Old 06-22-2013, 01:03 PM   #4
CDNWhiskey's Avatar
Are your lines sucking air ? Are your values are still set to winterize ?
Old 06-22-2013, 03:56 PM   #5
Took out the inline filter as soon as we got the trailer.
2011 Roo 21SS
2012 Ram quad cab
Old 06-22-2013, 03:58 PM   #6
Actually it is a bit better with the aerator removed. Just seems like one extreme to the other with and without it.
2011 Roo 21SS
2012 Ram quad cab
Old 06-22-2013, 05:02 PM   #7
JoeR's Avatar
I ran into this problem and it was the sediment from the zinc element in the hot water heater clogging up the valves in the kitchen sink. I replace the anode, used the wet dry vac to clean out the hot water tank (with a piece of silicone hose attached to the end of the vac to reach up into the tank) and used this as an excuse to replace the faucet with a Pfinster unit. Water flow was restored.
I took apart the old faucet and found the sediment in the valve units on the sink. I could have probable cleaned this out and been ok, but the new faucet looks nice.
2008 Toy Tundra DC 5.7L Bagged w/LTs
Hensley Arrow
2012 Windjammer 3001W, Atriumed
JoeR is offline   Reply With Quote
Old 06-22-2013, 05:34 PM   #8
CDNWhiskey's Avatar
From the aerator take the little white disc a part. 2 pieces. Honestly 3 tiny pieces of grit will plug the disc.
Old 06-23-2013, 07:49 AM   #9
Dave Lyon's Avatar
This is exactly what happened to me.......low pressure, and took apart the aerator and found a tiny piece of plastic from the water line. I cleaned it out and we're all good.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 06-23-2013, 07:53 AM   #10
hockeytownmom's Avatar
Mine is the opposite. I have great pressure to the bathroom, but very low pressure to the kitchen sink.
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
