Old 05-21-2014, 09:22 AM   #1
n4uaj's Avatar
Maiden Voyage
Got back from our first trip with the Shamrock 183 Monday and all went well. Pretty much checked out all systems including the furnace on a cool morning. The only ting I found slightly questionable was the bathroom heat vent. I'm wondering is it purposely restricted and not blowing strong as other two or do I maybe have a kink somewhere in the vent hose?
Bill
Bill
2014 Shamrock 183
1995 Chevy Silverado
n4uaj is offline   Reply With Quote
Old 05-21-2014, 09:31 AM   #2
Glad to hear all went well on your maiden voyage. Couple things about the bathroom heat vent. If it's the furthest from the furnace the air flow will be lower. And yes you may have a kink in the flexible hose or there could could be an obstruction in the hose. If you can access the furnace try to remove the hose and try sucking it clean with a shop vac.
Old 05-21-2014, 09:36 AM   #3
n4uaj's Avatar
The vent at the doorway blows good and it is close to the same distance away as the bathroom vent. It looks like it's routed underneath the sink and bath drain pipe so maybe it's punched off there a bit.
Bill
2014 Shamrock 183
