Old 07-01-2014, 09:55 PM   #11
I suspect it would work, but I'd have 2 concerns:
1. The plexiglass cracks pretty easy (drill the holes carefully), and I'd be concerned that when that rivet "pops" it would crack the plexiglass.
2. Don't know if the rivets come in stainless steel. If not, I'd be thinking about rust. There's basically a hole left in the rivet that will gather water.
2011 Traverse LT, 3.6L, FWD
Old 07-01-2014, 10:01 PM   #12
DK-in-SC's Avatar
I thought about the cracking too, so I might put some sort of washer between the rivet and the plexiglass. I use rivets to attach things on my fishing kayak and that has been in both fresh and saltwater with no signs of rust so I think it will be ok, but a drop of caulk in the hole wouldn't hurt either.
I'm guessing that you get the plexiglass custom cut from a local shop?
I live with fear every day, and sometimes she lets me go fishing.
2015 Shamrock 23IKSS
2008 Ford Expedition EL
DH-DW-D3K-DMTTSAP
DK-in-SC is offline   Reply With Quote
Old 07-02-2014, 05:46 PM   #13
I just went to Home Depot and bought a piece, then measured the cabinet wall and cut the plexiglass myself. Cut carefully. I had to do mine twice due to cracking. Also suggest you make a paper template first. I made an assumption (you know what those do!) that the bottom inside corner was square, so I was a bit off on the final install. It wasn't very much and the caulk I put at the inside wall and bottom seams covered it.
And with the extra plexiglass, you can do this so you can see your auto swapover regulator:
ID:	56968   Click image for larger version
ID:	56969   Click image for larger version
ID:	56970   Click image for larger version
Old 07-02-2014, 08:43 PM   #14
MOD Guy's Avatar
I would think the caulking where the PG meets the wall and shower base would be enough in these areas to keep it secure. I would try it with only one SS screw in the upper corner. A finish washer will have a bit of give to it, so if you just hand tighten the screw with the finish washer, you should be able to do it without cracking it. Another option is to just put a small dab of clear silicon in place of the screw. That should be enough to hold it.
Chuck Roder & Family
'07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab
High Springs, FL.
MOD Guy is offline   Reply With Quote
Old 07-02-2014, 09:01 PM   #15
Take The Road Less Travld
MuddauberE's Avatar
had the exact same issue with my Roo. Water will leak from the sides of the shower onto the floor. I thought it was the tub leaking from underneath at first. Even when trying to be careful, I would end up with water on the floor. Showers just aren't enjoyable when you're being too cautious. Instead of tub deflectors, I've used clamps the hold the shower curtains to the wall while I'm in it. Seems to work pretty well.
Name:	ImageUploadedByForest River Forums1404352855.238056.jpg
"Take The Road Less Traveled"
2013 Rockwood Roo 233s
2017 Ford F-150 EB
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
MuddauberE is offline   Reply With Quote
Old 07-02-2014, 09:22 PM   #16
Even with my PG and shield, I'd be interested in clamps. Where'd you get them?
Old 07-02-2014, 09:35 PM   #17
MuddauberE's Avatar
Amazon
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
2017 Ford F-150 EB
Old 07-13-2014, 08:40 PM   #18
Here is what I did. I bought the plastic weather stripping for the bottom of an exterior door $3 at menards. I flipped it upside down and attrached it to the top of the shower base . Then I used clear silicone between the top of the shower base and the stripping. I also added silicone were the stripping meets the sink cabinet. I works really well! Click image for larger version
Name:	ImageUploadedByForest River Forums1405301774.135147.jpg
ID:	58127Click image for larger version
Name:	ImageUploadedByForest River Forums1405301793.818438.jpg
t0rnado is offline   Reply With Quote
Old 07-13-2014, 09:14 PM   #19
Need pics of the installation.
Old 07-13-2014, 09:42 PM   #20
Here is what it looks like. Very simple peel, stick and caulk. My wife said it looks like part of the camper .
Name:	ImageUploadedByForest River Forums1405305707.958144.jpg
ID:	58140Click image for larger version
Name:	ImageUploadedByForest River Forums1405305764.892096.jpg
leak, roo, show, shower
