Old 08-03-2016, 08:49 AM   #11
It could also be an internal pump leak and you are not actually losing water.
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 08-03-2016, 08:58 AM   #12
jeff
jeff64's Avatar
Originally Posted by Guzzi View Post
Thanks. Can't find leak anywhere. Got feeling that internal pump leak is culprit. Just lasts fraction of a second plus only 2x in good 8 hours.
Not to hijack this thread but:
One bigger concern is how the heck will I ever get the water filter housing outta there. REAL LOW on space to work in. Would attach pic but to pc illiterate. Maybe end of season I'll dig in & remove/bypass filter. Don't really need or want it. Had the housing on our whole house filter fail years ago while on vac. What a mess!!!!!! Thanks all for your help
They're not that bad to remove. I'll admit space is tight. I cut the white hose close to the canister with a knife. On mine, the PEX went to a "T" where I cut the clamp with a Dremel with a thin cut-off disc and peel it away. Carefully cut the PEX at that point with an Xacto and peel it away. Don't mess up the barbed fitting, it will seal on the white hose. Mine had enough slack in the white hose to go onto the barb at the "T" and with a new 1/2" PEX crimp clamp, get it done and leak checked. Some that have done this put a sleeve in place of the filter assy., not necessary IMHO
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 08-03-2016, 03:31 PM   #13
Have you checked for a slow dripping faucet? How about the outside or inside shower? Is the toiletletting a little water seep into the bowl?
tjmezzan is offline   Reply With Quote
Old 08-03-2016, 03:36 PM   #14
ROCAMPER's Avatar
Our 2016 23ss has a very slow drip from the shower head. 1-2 drops an hour. It will cause our pump to cycle every now and then. I think I need to replace the shower controls but haven't justified the work vs 1-2 drips an hour.
ROCAMPER is offline   Reply With Quote
Old 08-03-2016, 06:12 PM   #15
All looks good. Thanks for your time
21SS
EcoBoost
Guzzi is offline   Reply With Quote
Old 08-20-2016, 07:52 AM   #16
bypass filter
to bypass your filter, just cut the line on each side, buy some Shark Bite push on fittings and a short piece of pex tubing, and it is a five minute job. My Roo had that done before I bought it.
mnoland30 is offline   Reply With Quote
Old 08-20-2016, 05:11 PM   #17
Sounds relatively painless. Thanks.
21SS
EcoBoost
Old 08-21-2016, 06:49 AM   #18
bareftn's Avatar
Originally Posted by youroo View Post
Yes mount Whole House Filter "OUTSIDE" you really want a Filter! Youroo!!
Is that filter mounted on the camper and easy off and on, Please share more pics with us on how you did it
bareftn is offline   Reply With Quote
leak
