08-03-2016, 06:24 AM
Maybe a slow H2O leak??
We are in the middle of a 2 week camping trip in our new 21ss. Trying to conserve water & grey/black tank space. Left water pump on last night in case grandkids had to use the can. Nobody got up tp use bathroom but water pump came on twice. Could we have a small leak somewhere? Gonna start clearing stuff out to check. Had new Roo in driveway camp mode for a while before we left & never noticed this issue. Could it be normal? Thanks
21SS
EcoBoost
08-03-2016, 06:27 AM
Yes, you most likely have a very small leak somewhere.
Bruce
08-03-2016, 06:28 AM
Could be "Air" but I would check for "Leak"also! Youroo!! Look at "Outside Shower"!
08-03-2016, 06:40 AM
Thanks. Will keep ya posted
21SS
EcoBoost
08-03-2016, 07:15 AM
Check the low point drains. Our popup had a small leak there that would kick the water pump on every once in awhile.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Gill" 2022 RAM 2500
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
08-03-2016, 07:21 AM
Yes you could have a small leak somewhere in your plumbing system and you should first check for that.
The pump could also be leaking/bypassing internally in the pump head.
There will be no leak to the outside, just loss of pressure in the plumbing system over a period of time making the pump run to satisfy pressure requirements.
08-03-2016, 07:42 AM
X2
If you can't find it by eye, hold a paper towel around all the suspect areas and look for seepage. If not, I 100% agree internal pump leaking in the head past the umbrella valves. Not to worry, my last 2 TT's have done it too. When it does that, I'll bet it only lasts for less than a second. Rock on!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
08-03-2016, 08:22 AM
Originally Posted by jeff64
X2
Thanks. Can't find leak anywhere. Got feeling that internal pump leak is culprit. Just lasts fraction of a second plus only 2x in good 8 hours.
Not to hijack this thread but:
One bigger concern is how the heck will I ever get the water filter housing outta there. REAL LOW on space to work in. Would attach pic but to pc illiterate. Maybe end of season I'll dig in & remove/bypass filter. Don't really need or want it. Had the housing on our whole house filter fail years ago while on vac. What a mess!!!!!! Thanks all for your help
21SS
EcoBoost
08-03-2016, 08:36 AM
Yes mount Whole House Filter "OUTSIDE" you really want a Filter! Youroo!!
08-03-2016, 08:43 AM
My pump would kick on and off all the time, I got the papers on it out and looked up how to adjust it, I used alan wrenches and adjusted it myself works great now.
2016 Shamrock 23WS
2018 F150 Ecoboost
08-03-2016, 08:49 AM
It could also be an internal pump leak and you are not actually losing water.
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
08-03-2016, 08:58 AM
They're not that bad to remove. I'll admit space is tight. I cut the white hose close to the canister with a knife. On mine, the PEX went to a "T" where I cut the clamp with a Dremel with a thin cut-off disc and peel it away. Carefully cut the PEX at that point with an Xacto and peel it away. Don't mess up the barbed fitting, it will seal on the white hose. Mine had enough slack in the white hose to go onto the barb at the "T" and with a new 1/2" PEX crimp clamp, get it done and leak checked. Some that have done this put a sleeve in place of the filter assy., not necessary IMHO
14K Equalizer
08-03-2016, 03:31 PM
Have you checked for a slow dripping faucet? How about the outside or inside shower? Is the toiletletting a little water seep into the bowl?
08-03-2016, 03:36 PM
Our 2016 23ss has a very slow drip from the shower head. 1-2 drops an hour. It will cause our pump to cycle every now and then. I think I need to replace the shower controls but haven't justified the work vs 1-2 drips an hour.
08-03-2016, 06:12 PM
All looks good. Thanks for your time
21SS
EcoBoost
08-20-2016, 07:52 AM
bypass filter
to bypass your filter, just cut the line on each side, buy some Shark Bite push on fittings and a short piece of pex tubing, and it is a five minute job. My Roo had that done before I bought it.
08-20-2016, 05:11 PM
Sounds relatively painless. Thanks.
21SS
EcoBoost
08-21-2016, 06:49 AM
Is that filter mounted on the camper and easy off and on, Please share more pics with us on how you did it
