Old 05-29-2016, 08:07 PM   #1
Memorial Day trip
At Frisco, NC. For 10 days. Ready to go Friday with everything packed and the electric jack will not work. No problem, there is a manual crank. Manual crank will not budge!! Starting to panic and thinking of options, I take it apart. Take the retaining bolt out of the big gear that connects to the electric motor, now I have manual. Arrive at the campground, the manual jack drops to the ground! Take it apart again and see that that the retaining bolt that I removed also held in place the pin that kept the jack in place! Fix that! Then I discover that the chrome tip of my exhaust on my truck is missing. Counting my blessing that the jack and the tailpipe didn't fall off while traveling and damage the camper. Now there is TS Bonnie coming this way. I don't care, a week camping is still better than being at work! All is good!!
Nccamper is offline   Reply With Quote
Old 05-29-2016, 08:33 PM   #2
ROCAMPER's Avatar
Memorial Day trip
Glad you're still having a good vacation!
ROCAMPER is offline   Reply With Quote
Old 05-29-2016, 08:57 PM   #3
Originally Posted by ROCAMPER View Post
You could use the jack from your car in an emergency. Then try and lower it down onto some wood till you get it fixed. It's possible it's a fuse somewhere, but I'm not sure when the tinge jack fuse is.
Just a side note. The first time I used my jack the button was reversed, so up was down and down was up. Can you crank either way using the manual part?
Thanks. I used a car jack to lift the tongue enough to put support to take the pressure off of the jack. It seems that the motor is lock up. The fuse is not a issue because even the manual crank was lock up until I took the retaining bolt out of the gear that connects to electric motor( the manual crank has worked before with the motor gears still engaged). When I leave next weekend ( because I have to make sure that the jack is lock in place ), I'll take some pictures. Just another day in paradise.
Old 05-29-2016, 08:59 PM   #4
Life is good!!
Old 05-29-2016, 09:44 PM   #5
I go RV'ing not Camping
jgourlie's Avatar
A bad day camping beats a day at work everytime
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 05-29-2016, 09:57 PM   #6
Memorial Day trip
You said that right!!
Old 05-30-2016, 06:31 AM   #7
bareftn's Avatar
a bad day camping ruins my retirement for a day
bareftn is offline   Reply With Quote
Old 05-30-2016, 06:48 AM   #8
Part of the adventure of camping!
dmac1951 is offline   Reply With Quote
Old 05-30-2016, 07:39 AM   #9
Butch Wilson's Avatar
There are no bad days in Frisco, NC . We were there two weeks ago. Will be returning in two weeks.
Butch Wilson is offline   Reply With Quote
Old 05-30-2016, 08:13 AM   #10
True. When it's not raining cats and dogs like it is now, this is my viewClick image for larger version
Name:	ImageUploadedByForest River Forums1464613944.065835.jpg
ID:	109550 and the sunsets a awe inspiring.Click image for larger version
Name:	ImageUploadedByForest River Forums1464613998.291162.jpg
