Old 06-06-2016, 02:26 PM   #11
I had the same issue but found it early on. I cleaned the camper real good and put the cover on for the first time. Lucky I was checking it one day and when I pulled back the night shade over the bed vent I found a mouse nest on top of the screen under the vent hood. I unzipped the cover and found a lot of mouse dropping on the roof. I cleaned it all up and two days later it was all back. I still don't know how they got under the vent cover. The cover gave them a way to climb up to the roof. They did chew a couple of the straps off the cover to help in the nest building. I removed the cover and solved the problem. I will never use the cover again.
Tomgky is offline   Reply With Quote
Old 06-06-2016, 05:23 PM   #12
If you can find where they are entering, you might try a combination of TTO (Tea Tree Oil) and peppermint oil. It works as a rodent repellent.
PenJoe is offline   Reply With Quote
Old 06-11-2016, 06:40 AM   #13
Wolverine 1945's Avatar
3 or 4 years back we had some critter climb out TT cover,,, and it eat very large holes in the cover ??? Have no Idea what it was,,, coon maybe ???
We have never seen a Squeal in our yard !!! Only have Pine Trees !!!
Wolverine 1945 is offline   Reply With Quote
roo, roof
