Old 06-20-2014, 11:33 AM   #31
CampingDixieDogs's Avatar
Just take it off and put one outside...save you a lot of headaches and frustration. Ask me how I know...
2014 Rockwood 2104s
2007 GMC Yukon
2011 Fleetwood Tioga Ranger 31M
CampingDixieDogs is offline   Reply With Quote
Old 06-20-2014, 11:44 AM   #32
Originally Posted by HSVBamaBob View Post
No! No A/C! Heat draws out the moisture and the DampRid will soak up the moisture.
Airconditioners, are nothing more then big dehumidifiers. If you want to dry something out, then button it up, and turn the air down. As the air moves across the evaporator, the moisture condenses, and drains off. The AC and a couple of fans, will dry it out quicker then anything else. It works in a house, and it'll work in a trailer.
katkt is offline   Reply With Quote
Old 06-20-2014, 11:56 AM   #33
Citrus County, Fl.
GL1800Rider's Avatar
Originally Posted by youroo View Post
What has worked for us! We can SEE what is going in,we can Dictate what Level of (Filtration) is going into the R/V,Potential Leaks are outside. We could not see thru those (Blue Inline) filters! Your water your choice! Youroo!!
Can you advise how you mounted the filter or provide a close up picture? I plan on eliminating the factory installed pos as soon as I get our new TT hopefully next week. I have used a couple of these when we were pumping creek water at our property in NC and they worked great but I just set them on the ground.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
Old 06-20-2014, 12:10 PM   #34
Yes,mounted a tube on the frame area where the (Under belly) is secured.Then another undersize tube that is mounted to the filter assy (Slides into the mounted tube). Keeps the filter off the ground,I have seen buckets,pushin brackets,and all kind of Other devices,but We like ours! Youroo!!
Old 06-20-2014, 07:39 PM   #35
So should I bother calling the dealer when we get home? Or just rig our own contraption?
hockeyfam is offline   Reply With Quote
Old 06-20-2014, 07:50 PM   #36
Slympicins's Avatar
Rig your own or follow the previous posts but what ever you do, get rid of the water filter inside the TT.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 06-20-2014, 08:37 PM   #37
Water Filter = Stupid Design
"I used to be disgusted, now I try to be amused."
Elvis Costello
2015 Sunseeker 3010ds
thatguy is offline   Reply With Quote
Old 06-20-2014, 08:41 PM   #38
BamaBob's Avatar
Originally Posted by VinceU View Post
Wonder if the bowl gasket was lubricated? If original it will be dry don't believe that bowl can turn under internal water pressure. The friction will prevent it when tightened.
X2! Dawn Dish soap is good for that BTW
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-20-2014, 08:44 PM   #39
BamaBob's Avatar
Originally Posted by MrJoe View Post
X2 - the evaporator coils will attract the moisture from the air and the condensate will be deposited outside. Now if you can reheat the air while the A/C is on, you'll have a dry camper in no time.
Originally Posted by OldCoot View Post
A/C is an oversized dehumidifier. That's why your A/C has water draining out of it constantly.
Soooo I am wondering...if you have a 50AMP unit (Dual A/C), seems like you COULD run both your furnace and your A/C (but they would be competing wouldn't they?) Still say DampRid is a better dehumidifier
Old 06-20-2014, 08:50 PM   #40
BamaBob's Avatar
Originally Posted by thatguy View Post
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. Ben Franklin
Urban Legend BTW...
(Vanity) Source needed for Benjamin Franklin quote
De-Hijacking thread back to catastrophes
cat
