Old 06-24-2014, 07:52 AM   #41
ebemis's Avatar
Have no worries HockyFam! Your rig will be just fine because you were there to address the issue!
Add me to the list of many other who experienced their water filter spin off! We had it happen at about 2AM one night in a Georgia campground. Fortunately the wash rooms had laundry so I was able to use EVERY towel we had to dry best I could....dried them in the laundry....repeated all night long. Once we got home that POS filter went right in the garbage and now I use the "in-line" style outside seems to work just fine. Use the Damp Rid when you park the rig and close it up and you won't have any problem with mold or water rot, I think that happens more when you DON'T dry and Damp Rid after such fun events!
Side note, I never did but a camping friend encouraged me to and now its a religious event...while hooked up to utilities, if we leave our rig for any length of time other than a brief walk, we shut the water supply off and then just turn it back on when we return....just food/water for thought!
Ed & Chris
Josh & Jaclyn
2012 Suburban LTZ
2013 Rockwood Roo 233S
ebemis is offline   Reply With Quote
Old 06-24-2014, 08:01 AM   #42
Should I be surprised that I called the dealer yesterday and they never called back? Guess people were right that rv direct doesn't care after you plunk down the money and leave!
Nothing smells foul or moldy inside the camper or in the compartments. We are home and will have to decide which way to go with this dumb filter. Looks like bypass or outside mount would work!
Thanks for all the great responses!
hockeyfam is offline   Reply With Quote
Old 06-24-2014, 03:48 PM   #43
ebemis's Avatar
BTW..once I removed mine from the rig (just rented the crimper from HD and inserted a PEX section of pipe with a union to the original piping in its place) I did manage to get a closer look at the thing. It appears by the plastic cylinder, that there are "teeth" that are intended to engage some kind of notch in the white plastic body. It would make sense that water pressure INSIDE the cylinder would tend to exert downward pressure (thanks to the angle of attack on the threads of the mating surface) thereby having the plastic cylinder "lock itself in" to the white plastic head. On my particular mating surface (threads in the white plastic head) I could find no such tooth at all....no piece of it anywhere in the cabinet where it exploded....nowhere nohow...no piece of plastic tooth anywhere. SO this seems to me to be the reason the thing unwound itself, nothing to stop it from doing so.
IF you must have a water filter inside, my personal recommendation would be to take that one out and instead install one of the GE whole house type ones from HD or Lowes as others have mentioned.....those have MUCH shallower threads and if you feel anal about completeness...just check the cylinder's tightness after a road trip to ensure it hasn't "rattled loose."
Me personally...I feel better having no such "potential major leaking point" inside my trailer..or more importantly inside a cabinet! I have had no problem with the external Camco In-line Filter, you can buy new ones cheaply on Amazon, or even at ACE or WalMart.
Whatever you decide, I still recommend the Damp Rid at least a few storage cycles just to be sure you suck out as much moisture as you can from cabinets and flooring. I hung the plastic bag ones inside storage compartments, from the bed rail and also put the big bucket ones down on the floor. I was AMAZED at how much water found its way to each of the Damp Rid containers...After two storage cycles, now I only seem to collect normal"atmospheric" water content from the wonderfully enjoyable Florida Humidity!
Ed & Chris
Josh & Jaclyn
2012 Suburban LTZ
Old 06-25-2014, 09:29 PM   #44
So is this issue with the bowl unscrewing itself happening only if the actual filter is installed and/or hooked up to campground/city water? Just wondering because I don't intend to use the filter as we only use the TT water for washing etc and we will only be dry camping in the bush utilizing the TT fresh water tank. We bring bottled water to drink. So am I safe or is this yet another issue I have to address before our maiden voyage in 2 and a half weeks...man, running out of time with non-stop issues here...water pump leak, toilet issue, etc, etc.
RACKMAN
2014 Roo 21ssL...towed by 2015 Ram Power Wagon
RACKMAN is offline   Reply With Quote
Old 06-25-2014, 09:35 PM   #45
I watched the canister unscrew itself without the filter in it. We were hooked up to the campground water supply with low to moderate water pressure. Initially it spun itself off with the filter installed. After we took it out it happened again. Not cool!
Old 06-25-2014, 09:39 PM   #46
keep camping's Avatar
I removed mine and put a 3 inch piece of plastic pipe, threaded at each end in its place. Ours was almost impossible to unscrew at the end of the season so I just trashed it. Usually fill water tank at campground and drain when leaving, we always bring drinking water from home.
2 Happy Campers & CoCoa the camping Yorkiepoo
2005 Salem LE 19FD
2009 Ford F150 Lariat
keep camping is offline   Reply With Quote
Old 06-25-2014, 10:06 PM   #47
SKnight's Avatar
Mine did the same thing. Luckily mine is outside in the control panel where water won't cause damage.
Here's the safe bet, it has to unscrew a good ways to actually leak, leave the wrench on in such a manner that if it unscrews it will simply hit the wall and stop. Use a zip tie on the canister under the wrench to keep it in place. That's how I finished my last camping trip with that filter.
I like the thought of having a filter, wasn't too keen on the blue external ones though. Since I'd have spent money tying the lines together to dispose of the filter, I decided to install a better filter unit. Here's what I installed.
GE 3/4 in. Inlet Whole House Water Filtration System-GXWH04F at The Home Depot
It doesn't come with a filter allowing you to pick your own. I got these.
GE Carbon Replace Filter 2-Pack-FXWTC at The Home Depot
Much higher flow rate, cheaper and I feel better filters. Plus, the housing isn't showing signs of leaking.
Oh, and I installed this filter setup for cheaper than the FR-1 filter element.
Old 06-26-2014, 05:26 AM   #48
Slympicins's Avatar
Would be even better if installed outside of the TT altogether. It was to much of a pain to drain when winterizing (did that several times while winter camping). There is no place I would want that thing inside our TT!
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 06-26-2014, 05:34 AM   #49
ebemis's Avatar
RACKMAN...have no worries focus yourself on camping and having fun, just be AWARE of this pesky little filter and its possible behaviors!
From my own personal experience I can attest that there are many folks on these boards with excellent ideas and feedback. When you read many of the threads and get yourself thinking about them, you can end up scaring yourself and then your camping becomes STRESS instead of the FUN it is supposed to be....DON'T let this happen to YOU! ;-)
For me, I now think like Slympicins....keeping my water filter OUTSIDE my rig provides me piece of mind and I sleep better without the fear of a middle of the night THUD followed by rushing water INSIDE my rig!
Ed & Chris
Josh & Jaclyn
2012 Suburban LTZ
Old 06-26-2014, 04:25 PM   #50
Slympicins's Avatar
minor catastrophe on 1st trip
I totally agree. Camping is to be fun not stressful. This forum is designed to help others from going through the stresses we already went through thus creating, more fun. Not everyone will experience the same issues as others but it sure helps those who are, or haven't been, ready for those issues to pop up. I know from reading about other folks issues has helped me tremendously. Hadn't read about the filter issue before mine failed. It really wasn't a huge problem since I was standing close. Had we taken the dog for one of those long walks it could have been really stressful. Camp on and have a no stress trip!
Chuck and Joanne
cat
