07-12-2011, 04:55 PM
Missing fresh water tank drain cap
I tried to fill the fresh water tank the other day and was amazed at how much water it could hold...UNTIL...I discovered the water flowing out the bottom of the tank into the grass.
This was the first time I put water into the tank so I never realized the dealership/factory never installed the drain cap.
I think I am the poster child for what not to do when you purchase a new camper.
- Make sure you complete a detailed inspection and test everything before you leave the dealership or allow the delivery driver to leave with signed paperwork.
So far I have had:
- Refrigerator that didn’t work because it was missing the thermocouple.
- Screen door slider that was way too big for the frame.
- Two snaps on the front tent that didn’t have the male part to snap it to.
- Missing drain cap on fresh water tank.
Minor issues in the grand scheme of things and we still love the 233s.
Hope everyone in having an enjoyable summer with their TTs.
V/r,
Dave
07-12-2011, 06:42 PM
Is your fresh water tank underneath the trailer? Or inside a cabinet?
03 Chevrolet Silverado 1500, 5.3 V8, 3.73
06 Rockwood Roo 23SS
Equalizer Hitch
07-12-2011, 08:02 PM
Thankfully underneath.
07-12-2011, 08:13 PM
u can get them at home depot, lowes, or most anyplace that sell plex fittings.
when i took mine back for service, the dealer removed the caps and put them next the hot water heater (from the outside). i purchased a couple new ones then found them when i was checking the hot water heater for full. now i have a spare set.
07-15-2011, 12:49 PM
You're not the only one to make this mistake. I winterized my camper last fall, took off the cap and stored it... somewhere. Completely forgot about it this year and went to fill the tank... and heard the water falling to the ground! Geez! I felt so stupid!.
07-15-2011, 02:30 PM
I lost my drain cap on my old PUP last year. Luckly the thread pattern was the same as a 20 oz soda bottle. Saved the trip.
07-15-2011, 03:33 PM
that's good to know.
07-17-2011, 12:28 PM
I had no idea it would work nor did I think of the idea. While I was trying to figure out a solution another camper mentioned the idea...and it worked.
07-17-2011, 02:55 PM
On our walkthru the cap was in a kitchen cabinet with all the paperwork and instructions. the service guy showed it to me, explained what it was and hwere it went, put it back in the cabinet.
A couple of days later we've got the TT home and i go to fill it with water, in the driveway, and i could hear water running falling on the pavement, looked under to see a missing cap and started to get upset then I remembered the cap from the walkthru!
Our dealer was 'slammed' but others are the RV show as being a glorified used car lot (and I would say that is thier appearance) but they were first rate in dealing with us, with delivery, walkthrough, etc. Everything was as they said it should be and it all worked the first time. Either FR built one right or the dealer really does a thorough PDI on their units.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
07-17-2011, 03:49 PM
i wonder when FR made this change. my '07 23SS has a drain T-valve, next to the FW tank.
i simply pull it up and the tank drains. when it empty, i push it back down.
no cap except where to fill it.
07-19-2011, 09:15 AM
prof_fate,
Come to think of it, I might have seen something that looks like a drain cap in the kitchen somewhere. Now if I can only remember where I might have put it.
07-19-2011, 09:39 AM
I have that on the freshwater tank too - but you also may have a low point drain elsewhere, the lowest point of any pipe/hose on the trailer so that you can drain out every drop of water. You need to do this before winter (so nothing freezes), after winter (to remove the antifreeze) and after sanitizing the system (to get out the bleach).
2011 Grey Wolf 28BH
07-19-2011, 10:56 AM
i do have them but no cap on them. just the drain valves above the open hose ends.
and since i live in California, no winterizing needed!
08-02-2011, 05:23 PM
where can i purchase a fresh water inlet cap?
08-02-2011, 06:35 PM
they're pretty standard, any RV parts place should have them.
08-03-2011, 02:55 PM
Will look at Camping World for the water tank cap, that's where we purchased the MH. Sometimes you can't see you face because of the size of your nose.
Also, found the drain to the potable water tank under the matress where the tank is located and a in-line switch that turns the drain on/off. KISS principle I guess. Why would the Manufacture want to tell you that?
08-23-2011, 03:42 PM
OK, all is good with my fresh water tank (sort of). I found the drain cap in the kitchen under the sink on the floor just as prof_fate mentioned. When I filled the tank I noticed a very slow drip from the area where the drain spout screws into the tank. Nothing major, just need to add thread tape to seal the drip.
Thanks to all for the help.
Dave
