07-17-2018, 04:38 AM
#21
Originally Posted by Troutd0g
A call to Forest River indicated that the unit was built with a manual awning. So the mistake was the dealership posting incorrect feature list on their web site. My opinion is that they owe something for this deception. I agree that replacing the manual with a power awning will leave unused holes that must be dealt with and that won't be easy or inexpensive. Also I have read so many posts about trouble with power awnings that I wonder whether I am better off with the manual one I have. I have to repair the stripped out lag screws holding one of the arms - the dealer said they would put larger screws there but that will only hold for awhile and it'll fail I predict. I'm thinking of filly NSG the holes with epoxy like JB weld or gorilla glue and then install the lag screws.
We'll see if the dealership does anything about the erroneous feature list.
Troutdog,this "Mystery Awning" has gone on way to long! As ask Before "Who is the MFG of this Awning/Model#/Picture of the Complete Awning that is on YOUR Trailer! My Money and WAG is you have a OLD Style Manual,that would be Very ODD! The way you describe the Bottom Lag Bolt leads to My WAG,But Like Hersbird stated and Posted a Very Detailed Picture and Info of it could be a Solare! If You would Post a Pic of YOUR Installed Awning it would Help Us ALL! Youroo!!
07-17-2018, 05:30 AM
#22
X2 would be better if the OP posted a picture of their awning as there are several brands.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
07-17-2018, 06:50 AM
#23
Originally Posted by TT233S
How can this be true if a couple of post before say power not as good as manual - were you say their the same?
I've own both and both work worked the same for me...…..I'm confused by this post below!!!!!
Why are you confused,,, I prefer the Manual awning !!!
07-17-2018, 07:49 AM
#24
Happy Keystone Owner
I’d be hitting that dealer up for free accessories or upgrades...like a sprung mattress in exchange for the overcharge of the manual awning. At least 300 bucks worth.
'15 F150 Ecoboost Maxtow Scab '19 Keystone Laredo 225MK
Days camped 2020-37 2019-36, 2018-24, 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....55
07-17-2018, 02:46 PM
#25
Hybrid trailer mattresses have to fold in half.
So traditional RV mattresses won't work unless the owner removes it before closing the bunk door.
07-17-2018, 03:17 PM
#26
I luv my power awning... so convenient...
If as you say it was manufactured with a manual awning then FINE... use the manual one BUT GET THE BOLTS FIXED CORRECTLY...
2014 Shamrock 183
07-17-2018, 06:31 PM
#27
I’m with the manual awning crew. I prefer it. I would put three flappers on each side. Run a ratchet strap from awning tube to under trailer frame and let the rain come
07-17-2018, 06:49 PM
#28
I have been using manual awnings for 35 years and just like them better. Takes me about a minute to put it in or out. No motor to go bad. Very easy..........
1966 Mustang GT
1986 Mustang SVO
07-21-2018, 10:00 PM
#29
Sorry for the delayed response I've been away on business, catching up now. Thanks for all the responses.
The awning brand is A&E. Forest River confirmed it was shipped as ordered. The dealership (LazyDaze) has taken full responsibility for the error in equipment listed in on the web page. They have offered to replace the manual awning with a power one. After reading various posts and opinions I may just stick with the manual one and avoid having holes in the side of the trailer that have to be filled. The manual awning seems to be a bit larger than power one and it is angled down which allows water drainage as well a perhaps better shade. The power awning would be convenient but it is one more thing drawing power and that could break.
Another consideration is if power awnings run off of 12v D.C. or 120v AC.
I need to check that out. If it requires more than 12v then I will definitely pass on it. I plan to do mostly primitive site camping.
07-21-2018, 11:14 PM
#30
It runs on 12VDC; but it's one more drain on your battery if you're boondocking.
2011 Traverse LT, 3.6L, FWD
07-21-2018, 11:42 PM
#31
Honestly I'd probably just stick with the manual awning since it's already on there, but ask for a few hundred bucks in accessories to make up for the fact that you were charged for a power awning thst you didn't get.
07-22-2018, 10:31 AM
#32
Great Thinking Guys !!!
Have you thought about installing legs on the power awning if you get one !!!
It would be something you should thinking about,,, unless you want to put awning away when it wind blows or it rains !!!
I think you can buy a set for somewhere around $200 !!!
07-22-2018, 01:16 PM
#33
Bracket kit $75 Painters poles @ Zoro $27.98 ea.
https://www.zoro.com/wooster-paintin...iABEgK-rfD_BwE
07-23-2018, 07:27 AM
#34
Originally Posted by OldCoot
That would be the smart way to go,,, did not know you were still selling brackets !!! I saw a guy a while back,,, he was using a tree limb support on the end of his poles !!!
I have made my poles so I can take them on & off,,, they were rattling,,, would not be a problem on a TT or a 5th wheel,,, but was on our Sunseeker !!!
