Old 07-12-2018, 04:27 AM   #1
Missing power awning on 2019 Shamrock 21SS
Just purchased a 2019 Shamrock 21SS. Web site at LazyDays listed power awning as an included amenity. Forest River also lists it as standard on their web site. Picked up the unit and the guy doing the orientation noticed the awning was manual. They said we could sort it out later and proceeded with the orientation. Paid cash and took the rig home and called back the next day to discuss getting the awning swapped. Now I'm getting the runaround. Said I have to work with Forest River on it. Meanwhile the bottom bracket holding one of the awning supports has already come loose with only a single use of the awning. Lag screws are stripped out! If an amenity is listed on the spec sheet and sales person includes it in the overview of what's provided, shouldn't the unit have it? I apparently paid for it. Anybody else have this happen?
Is power awning standard on a 2019 21SS?
Troutd0g is offline   Reply With Quote
Old 07-12-2018, 05:30 AM   #2
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
I would go well beyond the salesman or repair guy that's giving you the runaround. Go to the General Manager...involve Forest River...and if you still get no response my next stop would be the BBB to file a complaint, as well as any local "Consumer Reporter" you may have on TV in your area.
Robert & Estha Shiflet
'17 Cardinal 3456RL - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017: 712 ~ Nights Camping 2018: 120
rjshiflet is offline   Reply With Quote
Old 07-12-2018, 10:24 AM   #3
Finster's Avatar
According to Forest Rivers own web site, the power awning is listed in the standard package G. Im pretty sure this package is mandatory when ordering so Im not real sure how a manual awning made its way out of the factory to begin with. If they only offer power awnings, you would think that power awnings would be the only ones the factory would have to install unless it was swapped out by the dealer. Its not all that uncommon for them to rob parts off of unsold trailers to resolve warranty claims.
Flagstaff Shamrock Travel Trailers by Forest River RV
Does the control panel in the trailer have a switch installed to run the power awning? Id also check the invoice and see what is listed for options. If it lists "power awning", or "standard package G" which includes the power awning then it most certainly is the dealers problem. They sold it to you, you paid for it, they didn't deliver it. If you get nowhere with the dealer I wouldn't hesitate to contact the Forest River Flagstaff Service Dept. Ive had prior issues and went through Jake Carter. He could sometimes be difficult to get a hold of, but he was excellent to work with. Unfortunately, I see he's no longer listed as a contact for Flagstaff. Here is the new contact info for the new Flagstaff Service dept.
Forest River
RV Contact Us - Forest River, Inc.
For future reference, you probably should have withheld payment and not accepted delivery until the correct awning was installed.
2007 Dodge Ram 1500
2017 Shamrock 233s
Waterloo, Iowa
Finster is offline   Reply With Quote
Old 07-14-2018, 12:47 AM   #4
Thanks for the advice I went to the dealer GM and he was very eager to help sort this out. He actually called Forest River while I was there and they are looking into the matter.
Meanwhile the lower bracket that attaches the left side awning support arm has already come loose. It is secured with short lag screws into the side wall of the trailer. Apparently no backer plate so there's little holding power. What a terrible design. Have only pulled the awning out twice and already it's coming loose.
I will post a separate question regarding this to see how people have fixed it.
Old 07-14-2018, 03:19 PM   #5
D W
D W's Avatar
That's dealerspeak meaning you're about to get the "Bum's Rush".
My guess is that it came with a power awning, but the dealer swapped it out with a manual, and then over-tightened the lag bolts. I wouldn't have closed the deal unless the awning matter was settled first. Now, they've got your money, but you don't have a power awning.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
Old 07-14-2018, 03:40 PM   #6
Flybob's Avatar
It is not uncommon for dealers to swap out parts from inventory units to make a repair for someone who says "I am not signing anything until it is right". I would ask for the fix in writing. Tell them to order the correct awning and once it arrives call you to set up an swap out date. I would not take it back until they can actually do the repair.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-14-2018, 07:47 PM   #7
BillyBass's Avatar
I agree with rjshiflet I dont know how the dealer ship can do that to a customer.I blackball there name all over these sites
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites 2018 11 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 07-15-2018, 08:35 AM   #8
Wolverine 1945's Avatar
If I were you I would feel lucky to have the Manual Awning !!!
They are much stronger and made to use even in a rain storm !!!
I would traid our Power Awning for a Manual in a minute !!!
Power awnings are made for shad only,,, and should put away if there is a breeze blowing or it is sprinkling !!!
Unless you make legs for your Power awning !!!
Wolverine 1945 is offline   Reply With Quote
Old 07-15-2018, 02:47 PM   #9
dbarr's Avatar
Me too! Never had a motor quit on a manual awning.
'15 F150 Ecoboost Maxtow Scab '13 Freedom Exp. 233RBS
Days camped 2018-24, 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....54
dbarr is offline   Reply With Quote
Old 07-15-2018, 03:45 PM   #10
bikendan's Avatar
Had a manual awning on my '07 HTT and now have a power awning on my 2016 TT.
Though the power awning is convenient, I would take the manual over the power.
Equalizer WDH
awning, power, shamrock
