Originally Posted by bareftn
How did you run the cable so its not seen ?
1- I went behind the big TV in the main room and installed a cable splitter.
2- Connected a 30 foot cable..... drilled a hole in the wall and dropped the cable.....but it wasn't going nowhere
3- I unscrewed the DVD radio, pulled it out, and found an opening to dropped that cable.
4-I went in the bathroom, and in the cabinet under the sink, I grabbed the coaxial cable through the opening.
5- I drilled a hole in the floor and dropped the cable to the ground
6- Went under the camper and brought it to the front using tie wraps to attach it on the way
7- Drilled a hole where the front cabinet is and brought it up and installed it.
I did fill both holes I drilled with silicone that expend.
Total time to do the work (about an hour)
Some may think it's stupid to have a TV in the front, but when you go to bed at night, the closer the TV the quieter it will be !
Dre
