Old 04-08-2015, 10:11 PM   #11
jpgowin's Avatar
Originally Posted by Captn.Ken View Post
I have been looking for a box to fit behind my propane tanks. It looks like the one you have works nicely. But, I cannot find that box on web. Checked Lowes online and can't find it. How did you get it?
I bought it at my local Lowes store.
2009 Roo 23ss
2014 Nissan Armada
Former Trailer - '99 Coleman Niagara
Me, Wife, 5 daughters, 4 grandkids
jpgowin is offline   Reply With Quote
Old 04-08-2015, 10:12 PM   #12
jpgowin's Avatar
Originally Posted by Archicamper View Post
How well does your accumulator tank work and what is the brand?
The tank helps to regulate the water flow and prevents the pump from cycling too much. The brand is Shurflo, I bought it online at Amazon.
2009 Roo 23ss
2014 Nissan Armada
Old 04-08-2015, 10:15 PM   #13
jpgowin's Avatar
Originally Posted by wicked1 View Post
Nice but how was the battery box mod to do
The box fits perfectly behind the propane tanks and fits my (2) 6v golf cart batteries and (1) 12v deep cycle battery + wheel chocks and tools
2009 Roo 23ss
2014 Nissan Armada
Old 04-08-2015, 10:17 PM   #14
jpgowin's Avatar
Originally Posted by Tanddhall View Post
Wow, do you make home visits to look over what we have. You have some great ideas for the water system. The water drain will have to be one I do asap as crawling all the way to the middle underside of my unit is no fun. Thanks for the ideas and sharing.
I too got tired of crawling under the trailer and wanted to access it from the corner.
2009 Roo 23ss
2014 Nissan Armada
Old 04-08-2015, 10:26 PM   #15
hamster
Here is my non-pex drain
[IMG][/IMG]
hamster is offline   Reply With Quote
Old 04-08-2015, 11:21 PM   #16
Tanddhall's Avatar
Hamster, is your tubing on an incline, being high at the connection and going down to the drain valve so water will not stand in it during the winter?
2006 Wildwood 22FBS
2011 Chevy Silverado 1500
Tanddhall is offline   Reply With Quote
Old 04-09-2015, 09:36 AM   #17
hamster
It's pretty level. I'll have the valve open when I blow out the system with compressed air.
Old 04-09-2015, 06:47 PM   #18
If you're blowing out via the city water connection, you won't blow air into the FW tank and out the drain. The check valve in the water pump suction will prevent this. If you have a newer Roo, I guess you could blow air into the AF connection if you have one, and if you open the valve to the FW tank.
2011 Traverse LT, 3.6L, FWD
Old 04-09-2015, 08:32 PM   #19
wicked1's Avatar
Nice
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 04-09-2015, 08:50 PM   #20
vinmaker's Avatar
I too am interesting in a box like that. Also. How did you run the wires? Did you drill large entry holes for the cables?
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
23ss, roo, modifications
