Old 09-28-2015, 10:01 PM   #11
Velosprout's Avatar
I installed mine this weekend and my wife loves the Oxygenics shower head. I removed the old one, installed with the included double-sided tape, but also used one of the screws from the old mount for the new mount, and for the other screw hole (under the screw-off bracket on the new mount), just drilled a new hole and screwed it in. We won't be switching back to the old shower head. The only detriment is that the new pressure blasts some water over the top of the shower curtain...careful aiming of the handheld unit fixes that.
Velosprout
2014 F150 SCrew 4x4 Max Tow Heavy Duty Payload 3.5 Ecoboost 6.5' bed Ingot Metallic Silver
2015 Rockwood Roo 21SS
Velosprout is online now   Reply With Quote
Old 09-28-2015, 10:09 PM   #12
Actually there are two holes in the Oxygenetics mount. The second hole is under the swivel mount. The swivel mount can be unscrewed to reveal the hole. Now, I'm not sure they will match the existing holes so I just used the mount that was already installed. I did not like the angle the new mount aimed the water.
Anyway, as stated, once you use it you will never go back...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 09-29-2015, 06:44 AM   #13
jeff64's Avatar
X2 on the mounting...tape and 2 screws. They're short enough not to cause an issue
I went a step further and installed a single lever faucet. Seems like it is easier to adjust the temp and flow. Seems like we can take about 3 navy showers on about 7-8 gals. which is a plus considering the tank size
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 09-29-2015, 07:52 AM   #14
wicked1's Avatar
Ok so I mounted it with the one screw from the original factory unit I was not sure if the Oxygenics screw was too long for the wall and double sided tape not working well.
I lay in a towel down in the basin so it doesn't pull off the wall and bang around
Are the screw that come with the unit too long for the Roo shower wall? I may have to get some better two way tape and a little clear caulk to seal around the base.
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 09-29-2015, 11:38 PM   #15
2015 Roo 23IKSS
I mounted mine higher than the original shower, and it sits at a better angle (down instead of towards the curtain). I used 3m super tape and I'll probably pull the darn wallboard off when I try to remove it, which will be NEVER.
2014 Rockwood Roo 23IKSS
2012 Dodge Ram 1500 Hemi 4X4
Me, Hubby and Luna the Lab
sewingcybermom is offline   Reply With Quote
Old 09-30-2015, 10:00 AM   #16
wicked1's Avatar
Do the screws that come with work or are they too long?
2015 Roo 23IKSS
Old 09-30-2015, 10:05 AM   #17
If they are longer than the originals, simply cut them off with side cutters.
Old 09-30-2015, 10:09 AM   #18
DAISY BOYKIN's Avatar
Mount shower head
I used 3-m double tape from lowes, used the screw hole in the center of the mount. Used a stainless 3/4" long screw. I always remove the head from the holder when traveling. I just lay it on the floor of the shower. I also replaced the Oxygenic shower hose with a more flexible stainless
hose.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 09-30-2015, 10:16 AM   #19
BamaBob's Avatar
Use the "Factory" hose clip, take a pair of wire cutters and snip the factory hose clip so you can put the Oxygenics Showerhead Hose in the factory clip when on the road and remove it when you are camping.
Done Deal
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 09-30-2015, 10:31 AM   #20
Originally Posted by Silverback Iowan View Post
Used everything that was in there just changed the head. Works great
Me too --- could hardly be any easier than this ---------
bruceatlam is offline   Reply With Quote
mount, show, shower
