Old 07-08-2016, 06:02 PM   #21
drelec's Avatar
Recessed Holder into Vanity
Photos of our recent mod
ID:	113493   Click image for larger version
drelec is offline   Reply With Quote
Old 07-08-2016, 08:20 PM   #22
Screw it in the wall!! How much pressure are you going to exert on the paper. Ours has been in the wall (no studs) for four years without a problem. If this is the worst problem we have to face in RVing we are in good shape.
VMI'62
Edmund is offline   Reply With Quote
Old 07-08-2016, 08:25 PM   #23
Edmund - You must not have kids!!
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
Old 07-08-2016, 09:33 PM   #24
Scrub175's Avatar
Nice mod, have you considered cutting back the bolting and adding a nut to each to secure to the bracing?
Scrub175 is online now   Reply With Quote
Old 07-08-2016, 10:02 PM   #25
Those don't need nuts. They're designed to install where you can't get behind the wall.
Old 07-08-2016, 10:04 PM   #26
Scrub175's Avatar
Mounting Toilet Paper Roll Holder
I understand but was mentioning the add on to preclude any issues if they backed out and were cut shorter. The nut would better lock it down and prevent the bolt from backing out. Just a thought. Cutting the bolts shorter was just an idea since these are in an accessible area.
Old 07-08-2016, 10:51 PM   #27
Put mine on the inside of the door below the sink.
2016 Roo19 Hybrid
2015 GMC Sierra 4x4 Crew Cab
OK3wire is offline   Reply With Quote
Old 07-09-2016, 05:42 AM   #28
Wolverine 1945's Avatar
Looks Very Nice on the out side !!!
Be carful when reaching inside !!!
Wolverine 1945 is offline   Reply With Quote
Old 07-09-2016, 12:22 PM   #29
The Texas Traveller
DavidBo's Avatar
I guess I like to keep it low-tech when it comes to the TP roll...
DavidBo is offline   Reply With Quote
Old 07-11-2016, 12:24 AM   #30
Like it!
shamwow is offline   Reply With Quote
mount
