Old 07-05-2016, 05:01 PM   #1
Mounting Toilet Paper Roll Holder
I want to mount a toilet paper roll holder in the bathroom. The screws that came with the holder are 1 1/4. The walls are paper thin with not noticeable blocking inside the wall. Suggestions?
2013 Rockwood Roo 23SS
2007 Toyota Sequoia
tduff is offline   Reply With Quote
Old 07-05-2016, 05:24 PM   #2
Wall anchors and smaller screws. May look to mounting inside vanity door, or find a freestanding holder(Walmart, Target. ect....).
Sure you will find something that will work for you
JPBar is offline   Reply With Quote
Old 07-05-2016, 05:53 PM   #3
SeaDog's Avatar
I got around that problem by using a free standing toilet paper holder. Has heavy base and doesn't move around.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-05-2016, 06:03 PM   #4
Old Eeyore's Avatar
We used an over the tank TP roll holder in the 21SS. Hooked it over the top of the cabinet door.
On one trip the roll bounced off of the holder and rolled around in the bathroom. After that we flipped it to the inside of the door when traveling. (Never came off again. . .)
2016 Roo 23IKSS / 2011 Tahoe
2011 Roo 21SS / 2011 Tahoe
2006 Bayside / 2006 4Runner
1999 SantaFe / 2001 Sienna
1967 Nimrod / 1998 Outback
Old Eeyore is offline   Reply With Quote
Old 07-05-2016, 06:19 PM   #5
My hooked some type to holder on the under sink cabinet door. Works ok. I suspect it will wear the finish on the door.
Steve29rlx is offline   Reply With Quote
Old 07-05-2016, 06:29 PM   #6
Mounted it to a pc of Lexan and used double sided tape on the shower enclosure. Has held for 4+ yrs.
Name:	Toilet Paper Holder.JPG
Old 07-05-2016, 06:36 PM   #7
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
It's amazing what a few dabs of "GOOP" will do. Just put a couple of dabs on the back of the roller and use the same short screws to mount it. After the GOOP dries, it ain't going anywhere AND you can peel it off later on if you decide to move it, but it will not fall off or pull off from normal use. I hate drilling holes in things as it seems I always need to move stuff. GOOP works great!
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is online now   Reply With Quote
Old 07-06-2016, 12:13 PM   #8
Mounted ours inside vanity door. Easy to reach and out of the way. Had to cut screws short enough so they didn't protrude through the door, but screws into the solid wood hold strong.
tjmezzan is offline   Reply With Quote
Old 07-06-2016, 01:50 PM   #9
I mounted a recessed one on an inside wall.
John M
2013 GMC Sierra 2500DH CC, 4x4, D/A
2016 Forest River Vengeance 25V TT/TH
johnm1 is offline   Reply With Quote
Old 07-06-2016, 03:36 PM   #10
drelec's Avatar
Recessed Holder
X2
Mounted recessed holder on vanity. Had to add a couple half inch blocks for the backing plate to tighten up. I try to post a couple photos.
drelec is offline   Reply With Quote
mount
